W203 '05+ Radio Wiring Diagram?
Old Oct 7, 2007 | 02:06 AM
ufokillerz's Avatar
BMW X3, C280
Does anyone have a wiring diagram for a 05+ w203? I specifically have a 2006 c280. Been trying to install a D3 all night with a VW03B harness and cannot get it to power up. Thanks
Old Oct 7, 2007 | 02:31 AM
SUNILP's Avatar
2015 E250D
there is no switched power behind the stock radio. You will have to get it from the cig lighter. Also, if you have H/K sound, then you will have to run speaker wires from the d3 to the rear right of the car where the amp is located.
Old Oct 7, 2007 | 02:55 AM
ufokillerz's Avatar
BMW X3, C280
Thanks that is what i figured, would you happen to know if the VM03B works at it should for my car? I believe that i only have a stock radio/cd unit, no h/k here.
Old Oct 7, 2007 | 09:36 AM
ufokillerz's Avatar
BMW X3, C280
also should i cut the acc+ wire that i have wired to the harness? and just wire it straight from acc+ from cigarette into the pioneer harness? i'm not sure if i should keep the wire intact between the harnesses and just splice in, thanks
Old Oct 7, 2007 | 10:42 AM
blown93lx's Avatar
2007 C350 6M
Old Oct 13, 2008 | 09:54 PM
bumpnzx3's Avatar
W203 C230SS
i've read that if you switch the '12v' and '12v switched' leads between the VW03b and the aftermarket radio harness- that will fix the problem w/o having to tap into the cig lighter. true?
Old Oct 13, 2008 | 10:08 PM
bumpnzx3's Avatar
W203 C230SS
nevermind- looks like the 05+ do not need to the wires switched on the vw03b, just the 04-
Old Jan 31, 2010 | 12:05 PM
ChristianJan's Avatar
c230 Kompressor Coupe
Bringin back an old thread, but I need to know which wires are the fiber optics to the amp and which are the speaker wires. If anyone can help me that would be appreciated.
Old Nov 13, 2021 | 05:58 AM
GiulioTJ's Avatar
c320
HI there, I have a 2001 c320 and I have different wire colours on the 12v iso plug.
as you can see there is a yellow black and a green black and a black cable in smaller size.....
what do you think?
Old May 5, 2023 | 02:55 AM
what2be's Avatar
2007 C230
Fiber/Speaker?
You just thought you were bringing back a old thread... now im the king of old threads.. Anyway, did you ever figure this out? I have the same question. 2007 C230... MF2731 radio with changer in glovebox. which color fiber connector goes where on back of unit.
Old Dec 9, 2024 | 11:35 PM
jmschuldheisz's Avatar
E350, E400, C230
Interesting topic because I have a 2007 C230. I would like to install a CD changer. I already found the MOST plug-in but have no idea what wire I need to plug into the back of the unit.
