Mirror blinker customizing.....
Old Nov 1, 2002 | 07:57 PM
SKIDZ's Avatar
'06 CLS500
Just wondering if there are others out there who have done away with their incandescent mirror blinkers.
A while back, I had posted some details as to how I had upgraded my mirror blinkers to make use of LEDs.
Wanted to see if anyone has done the same.
Old Nov 1, 2002 | 09:01 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
do you want to change the color from amber to more of a white or "HID" look? havent read anything just asking really!
Old Nov 2, 2002 | 09:29 AM
MB-BOB's Avatar
Admin Alumni
See Garage
From lower on this page...
https://mbworld.org/forums/showthrea...threadid=21288
Old Nov 2, 2002 | 10:29 AM
ViKTORiOUS's Avatar
W209 - W163
i'm planning on doing it tomorrow with my dad. did you change all of the bulbs (6) in the one mirror or just the three outer? i want to get rid of the amber bulbs, so im wondering if it would be fine if i just changed the 3 outer bulbs and take out the 3 inner bulbs. would it work? thanks!
Old Nov 2, 2002 | 05:13 PM
SKIDZ's Avatar
'06 CLS500
Viktorious, you can use only the 3 outers however I don't recommend it. Something you need to consider if you do. By using only the 3 outers the mirror blinker will only be effective for vehicles in and around your "blind" spot. If that is something you're comfortable with.....then by all means, do it. For myself, all 6 of the incandescents bulbs were replaced with LEDs.
Old Nov 3, 2002 | 12:19 AM
Drew_ML's Avatar
'00 ML320 Elegance/'03 C320 4-matic
SKIDZ,
If I recall correctly, the mirror blinker strips are connected to the bulb-out malfunction system so that if the bulb goes out, the system will display a warning. How did you manage to get around this with the LEDs?
Old Nov 3, 2002 | 01:35 AM
couldnt you use the same device thats used in conjunction with the led indicators in the rear assembly??
Old Nov 3, 2002 | 02:15 AM
SKIDZ's Avatar
'06 CLS500
Originally posted by Drew_ML
SKIDZ,
"Load Equalizers" were used to draw the additional current necessary to fool the computer.
Old Nov 3, 2002 | 11:10 AM
Lynn's Avatar
If you are refering to the third stop light, those bulbs are incandescent, too. Page 350 of the Operator's Manual.
Old Nov 3, 2002 | 03:16 PM
Drew_ML's Avatar
Ah I see. I am familiar with these devices. Which one did you use? How many ohms and where are they mounted?
BTW, you didn't do this mod youself did you?
Old Nov 4, 2002 | 12:07 AM
SKIDZ's Avatar
'06 CLS500
Hey Drew_ML, don't think that because I was able to explain to you some details of my mods does it mean I'm capable of actually performing the mod. Fortunately, I have a very good friend that is quite competent in doing such mods. Sorry, but I don't have an answer for your question; simply cause I don't know.
Old Nov 5, 2002 | 12:08 AM
Drew_ML's Avatar
Not a problem, SKIDZ, I'm sure that I will, if not someone else, figure it out eventually, LOL. Thanks anyway!
Old Nov 6, 2002 | 12:23 AM
KompressorBabee's Avatar
2002 White C230 Kompressor Coupe(Black Interior)
Question Blinker lites.. folks
Alrites.. I see all these talk about LEDs on the mirror blinkers for the C230's.. help me out here, I'm planning to change those incadescent lights to have more of an hid effect.. So is the bulb size all 194 wedge bulbs? That's what I have found... Help me out please, thanx a lot :0 Those bulbs are so damn tiny.. I dun't think i want LEDS tho
