W203 Part numbers
#51
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
bone stock E55 AMG
Anybody know the part numbers for the passenger and drivers side low beam "outer ring" clamp??
These rings secure the low beam bulbs in the headlight housing. I need both sides because I got these headlights off a member a while back and he took out the clamps to install HID's and decided to tape the bulbs down in the housing
I want to get these rings so I won't have to tape my bulbs down my lowbeam HID bulbs anymore![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![](http://i216.photobucket.com/albums/cc89/03W203/Diagrams/A2208260189.jpg)
A220 826 01 89 clamping ring
is that what u r looking for?
#52
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
#55
Phone Parts
Used for 2005 C230 Sedan...
Vehicle core installation kit BQ 682 0965
Hardware kit BQ 682 0462
Linear compensator, dual band BQ 682 0829
Control module, MHI BQ 682 0936
Completer kit BQ 682 0907
Bracket A203 545 60 40
Contact plate A203 820 13 11
Clip A220 823 03 32
Antenna switch (w/ FAKRA) A220 827 18 42*
- *Not available as spare part – reference only!
IF EQUIPPED WITH Tele Aid
Solder splice A001 546 99 41
Crimp pin, black pin housing A008 545 55 26
Crimp pin, blue pin housing A016 545 41 26
Tape A006 989 84 85 10
Local Purchase
20-gauge, VIOLET-COLOR wire
CODE 669
Full Spare Tire
Spare tire shell A203 898 01 07 7c45
OR A203 898 01 01 1c45
Spare tire bracket A203 899 04 14 7c45
Rear lamp WITH reading lamps
Light housing A210 820 35 01
Clip A220 823 03 32
Local Purchase
CODE 669
Full Spare Tire
#56
A1715400617 Front Brake sensor CLK63AMG
A2115401717 Rear Brake sensor CLK63AMG
Buth i can only see the right side, dont know if the left one is the same?? And on EPC it doesnt look like 6/4 pistons???
edit:
Seems that the sensors are only at the right side of the car....
#57
Or A 203 610 02 To Chassis F 123374 to date 01-08-2004
(day/month/year)
#61
For 2002 C230 M111 coupe
001986807114- Washer Fluid Concentrate
2035403308- Optical Harness (for stereo)
A1110901080- Supercharger
A0031541706- Alt Regulator /Brushes (for Valeo 120A)
A1110980380- SC Manifold gasket
A1110980880- Red Rubber round gasket oil catch to SC
1111420880-Exhaust Manifold gasket-
W140589152100- 722.6 measuring stick (ie tranny dipstick)
2037270388 Drivers side rear speaker grill
0488 Passenger 8G69 color code- Quartzx
Here are the parts needed to retrofit the Aero Wipers on pre-2004 W203s:
203-820-32-44 wiper arm
203-820-27-44 wiper arm
203-824-07-49 cap
203-824-05-49 cap
203-820-10-45 blade
203-820-15-45 blade
"some have said that the blades are the same, but those are the part numbers i ordered and were installed on my car." (Not my car...still have stock ones)
20388012839744 - 2005 grill
A20372705288G69- Windows Switch panel- Drivers side (quartz) (for left hand drive Coupe)
A20372706288G69" " Passenger side
Hood Insulation-2036821326 2003
A2036820226 for mine....
0019880325- Rivets
Oil filter- 1041800109 (as ordered previously)
EPC also lists 1041800709 &
Oil Filter-104-180-01-09-28
But the 1st pn seems to be the right one.
Cabin Filter- 2038300918- Carbon Impregnated
or 2038300118- Paper only
A2033100295- trailer hitch?
A2038200045 L Wiper Blade
A2038200145 R Wiper Blade
A2038201745 ?? per parts.com - Both sides! No longer available seperately.
0005400966 side marker repair kit (ie bulb socket)
001 989 50 51 grease
001 989 14 51 lube both for sunroof
D2B ring cable-a2035403308
Seat Belt guide A203 860 49 85 (update 2002 to 2003 + style)
009893660 ??
N000912006066- Bolt for CDS sensor M6x15
Washer for CPS- N000125006449
Carpet- Q 6 68 0517 ?? Coupe, Grey
Rear brake disk
A2034230112
A2034210512
Pads
A0034206020
AMG Oil cap- A156 018 01 02
Fuel Filter- Bosch PN - 0450915003-85E
O2 sensor- Bosch PN- LS6272 0 258 006 272
NGK Iridium 2 steps cooler plugs for ASP pulley 5691
203-824-07-49 cap
203-824-05-49 cap
203-820-10-45 blade
203-820-15-45 blade
0019880325- Rivets
009893660 ??
Rear brake disk
A2034230112
A2034210512
Pads
A0034206020
#62
Does anyone know the part number(s) for the coupe OEM door sills / kick plates. They just say mercedes and are not illuminated. I've also searched several parts websites but having a real hard time find them...
On mine, the plastic that surrounds (and presumably hold down) the word 'mercedes' has become damaged. I'd like to replace the entire sill (and passenger side whilst I am at it).
#63
bump (for coupe kick plates)!
Coupe Floor mats (partial post by C230 Sport Coupe):
Java = Q 6 68 0516
Oyster = Q 6 68 0517
Ash = Oyster = Q 6 68 0518
Pacific Blue = Q 6 68 0519
Java = Q 6 68 0516
#68
05 c230
is there a certain auto tranny fluid part number for a c230?
also how many qaurts does it take?
thanks
thanks
#71
Something Slow
Power Folding Mirror
Left frame: 203 810 75 76 $457.50
Right frame: 203 810 74 76 $372.00
Crank Seal Front
0239978447
Lower Control Arms
2043302011 Right
2043301911 Left
Upper Control Arm
2043304411 Right
2043304311 Left
C32 12mm Sway Bar Endlinks
2033202689 x2
C320/C240 Sway Bar Endlinks
2033202889 x2
Stop Light Switch
0015453909
Crank Seal Front
0239978447
Lower Control Arms
2043302011 Right
2043301911 Left
Upper Control Arm
2043304411 Right
2043304311 Left
2033202689 x2
2033202889 x2
Stop Light Switch
0015453909
#72
'05 C230 Kompressor - Sport
Hey guys,
Does anyone of you by any chance have a part number for the sunroof cables?
I´ve got a '05 C230k and my cables are busted (the "spring cables").
It's imported for the US but i think it's the same, and if anyone can confirm that would be great.
I hope those are available..
