EvoSport Sway bars, my impressions...
GL450, Sienna SE
Well, Ive had them in for 2 days now. The verdict is, they are great. WIth the newfound power I have been pushing my car pretty hard. It feels very solid. Also, the car feels like it wants to straiten itself out more. When I turn, I feel more flat. My car doesnt lean. My friends who rode in the back said that it feels really good. The back just turns without leaning. Like it pivots. They were impressed. I guess the front and rear sway bars was a good idea. Im very happy with them. I take some pics of the rear one tomorrow. I cant see the front one because my car is too low in the front. Or its just covered and I just dont know where to look. :p
MBworld Guru
white and whiter
Re: EvoSport Sway bars, my impressions...
GL450, Sienna SE
Originally posted by bobdole
how much did they cost you and what model car did u put them on?
They are on my 2001 C240
Frank, Im pushing over 220 to the wheels for sure. Ill find out the actual numbers this Friday when I go back to dyno.
2002 C240 Classic
mach430, can i purchase the bars seperately. for example im interested in the 19mm rear for my car. will this be a good setup with stock 20mm front and H&R cup kit? also, is the rear adjustable too?
MBworld Guru
white and whiter
btw, is the kleeman kompressor for c240 the same as the c320? just curious.
don't forget to post dyno numbers!!
GL450, Sienna SE
I dont think you want bascially almost the same size front and rear sway bars. You will tend to break the rear a lot then (lose traction). The rears are 3 way adjustable.
I recommend the full kit. Its really nice. I might want to stiffen it up a little more to see how that feels.
FrankW: the C240 and the C320 both share the same blower. I think thats why I have a bit of lag, kinda like a turbo. Hehe. Its very progressive and kicks hard from 3000rpm and on. Around 4500rpm I know im on full boost. Its fun! Hehe.
MBworld Guru
white and whiter
GL450, Sienna SE
Originally posted by FrankW
hopefully i can see you one the street one day...
Date: Nov 16th Saturday
Time: 12pm
The Wheel Supply (TWS)
975 Fairway Drive
Walnut, CA 91789
THis is right by you! Better come out and say whats up! Hehe.
MBworld Guru
white and whiter
You should come out to the meets! Next one is coming up.
Time: 12pm
975 Fairway Drive
Walnut, CA 91789
Time: 12pm
975 Fairway Drive
Walnut, CA 91789
Originally posted by Jim Banville
Other than the adjustablility, how do these compare to the C32 stock front and rear sways in size?
Stock: 20 mm front and 13 mm rear
C32: 22 mm front and 16 mm rear
Evosport: 24 mm front and 19 mm rear
Eibach: 24 mm front and 22 mm rear.
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
thanks
Jim
2010 C300 4matic
I have a friend with a C320 sport that I talked to about swaybars. But are his bars already thicker than the stock bars? Are they the same as the C32 or somewhere in between?
GL450, Sienna SE
I meant to ask how were they different than the stock sways on the C240. Or are the sways on the C240 the same as those on the coupe?
thanks
Jim
thanks
Jim
2010 C300 4matic
His are exactly the same as mine. I had sports package too. He should get the sway bars I got. He will feel the difference. Its fun.
GL450, Sienna SE
But are the sport bars different than the non-sport? Same as the C32? I'm not sure. For my coupe, the most I would do is the C32 rear bar that a couple people have done. I mentioned this to him. But he wonders if his bars are already thicker than the coupe and the non-sport C. If his are same as C32, then he obviously wouldn't need the C32 rear bar.
