Air Flap Actuator?
I think you press and hold the Recirc and Defrost buttons, and it will cycle through. Might fix it.
Check your airfilter, switch it out if needed, and Reset the code.
Let us know.
E
Let us know.
E
Have you checked the condition of your air filter for the engine yet?
If you end up replacing the engine air filter, you need to reset the code too.
E
..its getting colder here in boston, so I'll be doing this more...
) The flap noise is probably either the stepper motor or the flap actuator arm connected to the motor shaft (most common) that directs air to the footwell.
I'm waiting to hear what he say about the condition of his air filter
E
https://mbworld.org/forums/c-class-w203/177068-noisy-air-conditioner-stepper-motor-replacement-clicking-hissing.html post #18
DIY possible with patience.
