DIY C230K sedan oil change W203
What does the manual say for a 04 c230? I remember the last time i checked it was 0w40 but when I called the dealer to make sure today, They said 0w40 are for amg's only and that I should use syn 5w30.
Debadged 6-Speed '05 C320 Sports Coupe
Mobil 1 5W-30 does not have acceptable ratings for your vehicle.
If checked, much of this would agree with the information within the glove box, plus the additional information since the manual was printed.
Yes, the manual specifies acceptable multi-viscosity gradings, but of greater importance is the MB rating. According to Wolfgang's ML Page web site MY '04 vehicles require oils that meet MB 229.5 or MB 229.3 rating.
Topside does look a ton easier. I just finished doing it from the bottom as recommended by my buddy. He was saying b/c from the top, not all the oil is removed. I guess it could be negligible though.
Like everything else on this car, you would have to remove a plastic shield to get to anything underneath the chassis. They're easy to remove.
I'm suprised no one has said this; you should really be torquing the fliter back to spec, so that you don't overtighten, like someone else did above. Yes, you'll need to buy a torque wrench, but you should have one anyway for your lugbolts.
I've been doing the topsider way for years now. I have no idea other than stubbornness why you'd go the old-fashioned way on these cars.
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Great post, very detailed and easy to follow.
Had difficulty removing the filter element from the holder, you really have to pull hard to separate it. Unfortunately that is the messiest part of the job
I used a Moeller extractor from West Marine in Toronto, looks identical as the pictured in the top of the thread except it is smaller 4.5L instead of 6.5L. The larger size sells at other marine stores for $105, I got the smaller one for $59, I'll save the extra $46 and do it in 2 steps thank you very much.
Canadian prices
Oil Extractor $59 West Marine
Oil Mobil 1 Euro formula $8.99/L Cdn Tire (dealer sells it for $10.70)
Socket $9.80 Cdn Tire
Filter $19.31 MB
all of the vertical extractors seem to have been made by the same company as they are identical except for the name on the box Moeler = Pela = Mity Vac
Sucking the oil out was the easiest oil change I've ever had to do, clean and no tell tale signs of drips etc, no matter how careful I was doing the drain method on all my other cars, you always get your had wet as soon as the drain is open. Not to mention the odd time dropping the plug into the pan.
I especially like the filter arrangement no climbing underneath and fighting with a filter clamp in an impossible to get to position (easy when you are in a pit but not in the backyard on your back, my Acura CL was a PAIN
Canadian prices
Filter $19.31 MB
oil overfill alert
Hey Taiwanese....I keep getting oil overfill alert...although computer says oil level is good....do you think its from numerous oil changes were mech did not allow enough time for all oil to drain?? I've read that the oil level sensor is very accurate
I'm going to do oil change myself this time ...and try to drain 100%
Any ideas??
Any ideas??
Any ideas??
Any ideas??
I don't know.
But I think it's good that you do it yourself this time.
Make sure you give yourself some time to fully pump or drain out all the used oil. Put in exact amount of oil according to your manual.
Have fun.
Taiwanese:
I changed my oil yesterday and got out 5L, not knowing if there is a .5L left in the engine, I only put in 5L and wanted to see what the reading is. I checked on the screen and said that oil level was fine. However I had yet to start up the car and thinking that the level would go down as it would fill up the filter area.
Problem now is that I can't get a reading from the check oil level function, it says to wait and as I am waiting the screen changes to my trip odo and does not return to the oil level function, I waited well over 5min
What am I doing wrong to check the oil level?
Wish that they spent the extra $0.30 and put in a piece of metal for the dipstick, life would be so much easier
Taiwanese:
shut off engine, remove key
wait 10 minutes
insert key
turn your key without starting engine
go to oil display
Tried that but what I get is the message 'Observe waiting period' then it goes to the Odometer and never to return to the actual measuring
Everyone makes jokes about the electrics in a British car, beginning to think that the Germans are even worse
come back in 10+ minutes?
oil change
#2 on mercedesshop.com diy section applies to most models.
http://www.mercedesshop.com/Wikka/OilFilter2
For level in models without the dipstick
follow instructions in your manual.
http://www.analogstereo.com/mercedes...ers_manual.htm
oil quantity is in the specs section of the manual.
fleece filters from autohausaz.com and 0w40 mobil syn
ohlord
harborfreight tools has a topsider clone 2.5 gallon capacity for about 20 bucks.
ohlord
2005 M271 - "Down and Dirty" oil change - this is a GREAT time to inspect youtr chassis, paint rust, service the calipers and braking system, clear coat your hard lines...etc - Living in Buffalo has the perks!
Jake
(I made this DIY as simple as possible and did not use a lift, my custom jack pads, just normal tools...so anyone can do it!)
Jake
