Sponsored by: Red Tiger
ESP Visit workshop
Old Nov 12, 2007 | 02:26 PM
garvard's Avatar
Lightbulb ESP Visit workshop
It's 3 days as I get a "ESP Visit Workshop" light and ESP button on dash doesn't work. Diagnostic didn't find any problem. What can I do? Please advise.
Garik
2003 C320 4Matic
Old Nov 12, 2007 | 03:07 PM
ctC230K's Avatar
excites your girlfriend
Garik
2003 C320 4Matic
Were you doing some donuts recently? I've gotten that message before... usually resets itself after you turn the car off for a couple hours. If not, take it to the dealer, your ESP controller might be bad or need a reset.
Old Nov 12, 2007 | 03:45 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Someone else had a "Yaw Control Sensor" go out recently. Since this sensor is an integral part of the ESP system, it's possible that your ESP failure can be attributed to the different sensors involved in the ESP system.
Have your dealer check out your sensors at your earliest convenience. This is probably a dealer-only job. I doubt an indy-mechanic can rectify your problem due to the complexity of the car's electronic systems.
Old Nov 12, 2007 | 05:39 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
check your rear tires...
i dont know if i am tying 2 things together... but my esp light had been on for about a week and a half.... turned my car off and on it and it would still stay lite... doing the reset thing turning the wheels all the way to the right and then to the left did nothing.... not until we had a heavy rain and my traction sucked in it did i notice my rears tires where basically bald. i replaced the tires and the esp light has not lite up since... approx 2 months
-carino
Old Nov 13, 2007 | 12:48 AM
garvard's Avatar
Another malfunction I got is: "Break pads wear". Does ESP light connected with break pads?
Old Nov 13, 2007 | 11:46 AM
ctC230K's Avatar
LoL no, you need new brakes.
Old Nov 13, 2007 | 12:03 PM
WaveyKat's Avatar
Something Slow
turn the steering wheel all the way to the left then right if that doesnt work you may need to replace the module
Old Nov 15, 2007 | 02:47 AM
garvard's Avatar
I checked and found that break's wire was cut. After replacing break signal disappear.
I think my problem related with front axle. Because front left steering knuckle is contorted after accident. I already ordered a new steering knuckle and hope that problem will be resolved.
Old Nov 15, 2007 | 01:46 PM
merc200k's Avatar
c200 kompressor
eps fault
i was the same problem....go to workshop and say that clean one sensor at whiles...after make reset the fault and work ok...
this happent when rain a lot....
Old Sep 25, 2019 | 07:41 AM
ronniecr_2000's Avatar
MB R-500 Model 2006
Garik
2003 C320 4Matic
Clean the sensors at the wheels (front and back) by removing T10 knots, reconnect the ESP error may no longer appear.
Old Sep 25, 2019 | 05:36 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Wow, a reply to a 12 year old thread? Well, always good to see potentially useful info being added to the
forum. If anyone looks at this in the future, they can use the iCarsoft to read the ESP codes and
determine exactly what needs replacing. I suffered with a constant esp code for years til
I got an SDS diag and found it was the Yaw sensor. Which at the time was $700.
Some years later I finally purchased it off ebay for $30, and no issues since.
Also had one wheel sensor replaced along the way.
Old Oct 26, 2019 | 12:32 PM
A_ZMAN7's Avatar
2007 s550 , 1993 400e
I have an esp issue also
Wheel sensors check OK
Steering handle sensor OK
Replaced Yaw sensor still giving code
Replaced ESP module still giving code.
Dud I miss something?
