Rain sensor?
Old Nov 19, 2007 | 10:52 AM
chazzz's Avatar
'05 MBZ C230K and '09 MBZ C350
Rain sensor?
My wife and I just got a slightly-used '07 C230. It didn't come with an owner's manual, but the used-car dealer will get it for me in about a week. We're a first-time Mercedes owners. Did the search in this forum, couldn't find anything.
Question: The rearview mirror is attached to the windshield. By standing in the front of the C230, I see some kind of sensors on the windshield (where the rearview mirror is). Do I have a rain-sensing wipers? If not, then what is it?
I have a BMW 335i, and it came with rain-sensing wipers. I thought the C230looked similar to what BMW has...
thanks -charles
Old Nov 19, 2007 | 11:13 AM
e1000's Avatar
a quarter mile at a time
i belive the rain sensing wipers come with the sunroof package
Old Nov 19, 2007 | 11:41 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
thanks -charles
Rain sensor is combined with the light sensor, so that can not be the que. Easy to tell, though: just sprinkle some water on it and see if it activates the wipers.
Old Nov 19, 2007 | 05:19 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Turn the wipers to position 1 on a sunny day, ignore the first wipe, then see if it wipes again (wait 1-2 min).
Old Nov 19, 2007 | 05:52 PM
Cloudz's Avatar
2007 C280 Avantgarde
on that note, do you guys actually like the sensors.. I personally think it's sort of bad and useless
Old Nov 19, 2007 | 06:17 PM
RA71325's Avatar
I find it useful under some conditions.
Kal
Old Nov 19, 2007 | 06:19 PM
c230yvr's Avatar
How well they work has been asked before, and everyone seems to have different responses. I think they work well, but others say they wipe too fast or too slow. I think it comes down to personal preference. If you have rain sensors, you wont be able to set your own delay speeds, so you'll have to live with it....
Old Nov 19, 2007 | 10:11 PM
sludge's Avatar
2003 C230K Sedan
I think my rain sensor works well. The only thing I don't like is that if you forget to turn it off, when you start up the car the next time, they run for one cycle. The dry wipers drag across the windshield. In the manual it says to make sure you turn it off, because if you don't the above will happen, possible scratching your windshield. Duh, couldn't they have programmed it to run only when it senses rain after you start up the next time??
Old Nov 20, 2007 | 02:30 AM
T.O_c240's Avatar
'15 C400, 03' C240, '79 240D
I'd have to say that i like them only half the time and that half is when they actually work normally - the other half of the time they wipe way to dam fast. Im thinking should i use some sort of glass cleaner or product that might make the water bead off the sensor area - would that help the wiper in judging how fast/slow to wipe?
Old Nov 20, 2007 | 12:10 PM
Buellwinkle's Avatar
I love the rain sensors, especially in So Cal where it rains in a fine mist and stops and starts. The key is to keep the winshield clean as debris in that area confuses it.
Old Nov 20, 2007 | 01:07 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
-- i think the rain wiper sensors are actually on the hood.
-- the sensors that you see for the mirror are probably the day/night sensors as well as the garage door IR
----- these are all "i thinks"
enjoy your new car!!
-carino
Old Nov 20, 2007 | 05:03 PM
chazzz's Avatar
-carino
Thanks. I don't think Garage door remote control is IR. These remotes send out the radio waves.
Old Nov 20, 2007 | 06:18 PM
aznmode's Avatar
2010 c300
-carino
That's what I thought too. There's a black round sensor type between the hood vents. Unless that is the light sensor instead.
Old Nov 20, 2007 | 10:07 PM
blown93lx's Avatar
2007 C350 6M
Maybe this is fixed for MY07 but I leave mine in the 1 position ALL the time. They do not wipe when I turn the car on.
Old Nov 20, 2007 | 10:08 PM
blown93lx's Avatar
2007 C350 6M
-carino
The sensor behind the mirror is DEFINITELY the rain sensor. Throw some water or put your hand over it, the wipers wipe immediately.
Enjoy
Old Nov 20, 2007 | 10:32 PM
sludge's Avatar
2003 C230K Sedan
Good to see that they corrected this. It sounded silly and easy enough to fix. Otherwise I would leave it in the sense position all the time.
Old Nov 21, 2007 | 11:59 AM
I know it's the rain sensor behind the mirror because my last C230, sans sun roof, didn't have the rain sensor so I know the difference.
Old Nov 21, 2007 | 06:53 PM
Gudzy's Avatar
2006 ML500 & 2011 E350 4matic
Rain Sensor
The unit that is behind the mirror houses both the rain sensor and the auto headlight sensor.
Bill G.
2002 C240
2006 E350 4matic
Old Nov 24, 2007 | 04:11 AM
Johnsct's Avatar
2006 SLK280
The rain sensor works great. Every now and then it goes brain dead and starts wiping in dry weather. Most of the time it does what it should.
