Parking brake release problem???
Old Dec 11, 2007 | 10:35 AM
Matt@Felsham's Avatar
2004 54 C220 CDi Avantgarde (Spork Pack + Harmon Kardon)
Hi everyone,
Well after a couple of thousand miles on the clock the C is going well, apart from im still not convinced my HK is working properly and a small problem with my parking brake (Handbrake)
Basicly I keep getting the error message on the dash that the parking brake is still on when it isnt!!! the only way to get rid of this message is stop apply the hand brake and then release it again... and it only does this from time to time....
Any of you know an easy fix or have experienced this problem???
Cheers
Matt
Old Dec 11, 2007 | 12:02 PM
LuxuryC240's Avatar
2003 C240
Originally Posted by Matt@Felsham
Hi everyone,
Cheers
Matt
I noticed mine did that a few times last month, not sure what the problem was, but haven't experienced it again, I had to do the same thing to rid the red light.... It happened right after I switched back to the stock wheels...
Old Dec 11, 2007 | 01:07 PM
wvadam's Avatar
C230 COUPE 2003 M271
the phisical sensor maybe be loose and or the wires going into the sensor. my sensor was loose, needed to be pressed back into its fitting.
Old Dec 11, 2007 | 05:31 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
It may be the spring tension for the pedal return. If I get this message, I just lift the e-brake pedal with my foot & the light goes out. Shouldn't happen, but I'm not going to the shop over something like this.
Old Dec 11, 2007 | 06:21 PM
mleskovar's Avatar
'17 Jaguar XF
Sounds like the brake release isn't returning all the way....common problem caused by the pbrake mechanism being rusted. You can access it through a panel beneath the rear seat cushion. Search and you'll find pictures.
Old Dec 12, 2007 | 09:19 AM
Thanks guys...
Will give it a look over the weekend, its too blinking cold to be outside with it today!
Matt
Old Dec 19, 2007 | 01:34 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
This reply shows the parking brake fix for my coupe.
