Heated Seat Retrofit
I read god knows how many posts regarding the possibilities of installing heater pads in my W203.
If i kept it OEM does anyone know what models i could look at in terms of using their pads? I believe that the A-Class and SLK's are a option.
I know there are a few people who have retrofitted these to the rear seats as well, the same questions applies!
Thanks in advance.
You can use most aftermarket pads. You cannot order w203 pads alone since they are stitched with the leather.
Am i right in thinking the part number for the harness is A2035403005?
Does the harness come complete with all the relevant plugs for all the connections?
As i understand it from the following LINK the following connections will be made:-
1 - Upper switch row
2 - Ground
3 - Heater pads
4 - Front Sam
5 - ?
What is connector X35/33?
2 - Ground
3 - Heater pads
4 - Front Sam
5 - ?
i'm still waiting for the part #s from u...
I have 2 or three sets from old w126s that are not in use anymore (just the heating pads) i figure these will work-- but what about the voltage??? would there be a difference on what is run through these-- i know this is pretty off the wall but if i do not need to order pads, all the better for the pocket book
mj. keep on me for them ( remind me)i know i have the part numbers at the house!
At present i'm not sure whether to use after market or OEM pads from another class.
The one i would be looking for is for a saloon with all the options - heated seats, parktronic, rear blind, ESP, Door Lock, head rest, interior sensor, tow alarm.
Thanks ALL! - Any and all help is GREAT...I hope to use this to get the parts I need to fire a signal to a control module to power up vented seat fans and other "options"!
Jake
CLK full Switch Row (schalter)
Made in Germany.
part # -
on unit: 209 820 48 10
on box: 209 870 16 10
so which one is it ?
beats me, go with the one on the unit !switches from left to right:
- Heated driver seat (top) / Vented driver seat (bottom)
- PTS (Parktronic)
- Sunshade (up/down)
- ESP
- Door lock
- Rear Head-rests
- Tow alarm (top) / IMS (bottom)
- Heated passenger seat (top) / Vented passenger seat (bottom)
Carlos
Saprissa
