M271 Leaking Cam Sensors
https://mbworld.org/forums/c-class-w203/237667-m111-leaky-cam-sensor-replacement.html
Good news first: There is a campaign to upgrade all bulbs, had all my bulbs replaced to "long lasting extended use" bulbs...whatever that means. All I care is my right rear tail lamp works again so no more worry bout mr. po po pulling me over.
Bad news: The cam sensor wire extension was not performed as no evidence of leakage was found
(I wish they would have just done it anyways!)Good/Bad news: Tranny was leaking. Replaced all sorts of seals, rings, etc. Also replaced parking detent attached to rear cross-member support and hydraulic something or other (don't have my invoice with me and can't quite remember). Good news is they fixed it all for free under warranty, bad news is it happened in the first place.
Anyone else have a tranny leak on them?
As far as the transmission, I had the exact same leak. They did the whole parking detent thing as well. At 2,000 miles I had the "normal' transmission connector leak, but then later I had the parking detent leak. I wonder if this will crop up with other owners.
Leif W.
does that mean i dont have to pull the plugs off and use contact cleaner on them? does the wiring harness patch isolate the oil leak problem?
My had just *started* leaking, so there were only a few drops, nowhere near the 1-2L mark like some other users here. You need to ask your SA the extent of the leak in your car. If your cables are clean, then there's no need to look at the plugs or ECU; your SA would've done that for you. (I double-checked my ECU; it was completely dry)
Yes the patch isolates the leak, so if your cables are clean, then consider yourself lucky
anyways, they cleaned all the wires out when they replaced the cam adjuster/sensors and wiring harness, nothing on the wires yet.. should i be worried??
the ecu is on top left of the block right? so just pop open the cover and see if there is any oil in there??
my Mercedes Benz Specialist changed these two wires for me with updated versions (bought by me from Mercedes Benz Cyprus) that supposedly will not cause any oil leaks, even though my current wires were clean and looked as new.
Change took him five minutes to do.
After the wire change, I experienced some kind of power reduction, not massive, but noticeable.
Any views on this?
2 X 2711502733 and they write on them:
DELPHI SLOVAKIA WERK
SENCIA DZ2SK
ZD 07.07.03
FD 23.04.08
These seem to be the correct wires, but, how come I get slightly reduced power?
these two cables, costing as much as they do, is pure robbery btw. WHAT is MB thinking??
They make a mistake and then they want all buyers to spend at least 100$ on a pair of wires, that should cost most probably 10$ each.
thanks!
thanks!
I get about 560 (typical) - 640 (best record) km between tanks, with 95% city driving. How about you guys?
Ed
Ed
Here are pics of the sensors (from page one):
https://mbworld.org/forums/showpost....1&postcount=13
There are 3 bolts per sensor, and 1 connector per sensor. Disconnect the sensor and check for oil in the connector. If there's oil, order the part numbers listed, remove the 3 bolts, replace the connector, add the isolation wire, and you're done.
