Engine misfire on C230 w/Kleemann pulley (M111)
So about a week ago, I had a check engine light, and I noticed that under heavy acceleration, or acceleration with a lot of weight in the car, the engine started to have a tendency to misfire. Keep it up for a few seconds, and the cylinder shuts down. If I stop, turn the car off ofr a minute, then turn it on, it behaves fine. So I go to a shop, find I need a new fuel filter and MAF (mass air flow meter), and the car is as good as new.
...Not more than a week later, and the same thing is happening. I'm about to rip someone a new one at the repair shop. Any ideas why this might be happening? I *really* hope it isn't the pulley, because that will really tick me off to no end.
It's an '02 coupe w/manual transmission, and the Kleemann boost pulley added on.
I keep a spare in the car.
Takes about 5 minutes to replace.
They're under the red cover, 2 bolts hold them in place over the
plug, and one electrical connector.
Very self explanatory.
Replace all 4 every 50K for troublefree driving, and invest in an OBD code reader so you know which cylinder is misfiring.
A cooler plug is good to have as well.
See my sig.
Changing the plugs is NP also,
the only odd tool I use is a telescoping magnet to fish them out, and drop them down in...... carefully as to not damage the tips.
before I did this i just put the CAN scanner on it for kicks and it pulled a code for "bank one too rich" --- good thing i bought the plugs last week on the way home
when i pulled them last night they were autolite platnums and were really white and worn down (the car only had 60k on it????) but anyway after i replaced them it was a whole different car (that and the throttle reset for adaptive transmission) ANYWAYS --- the issue has not come back and we drove the car pretty hard last night and this morning so i will pick up the switches to keep as spares on the way home if it happens again
Koru-- it is as simple as 3 allen bolts, 8 star bolts, and 4 plugs (repeat in reverse)
See my sig.
ive got an old obdII scanner i hooked up to my car the other day, and i guess i need new software because it wont even initialize with my car. i fgured it would at least connect to the 2006, even if it didnt recognize the codes because its 2003 software still :P
if youre gonna use that brand at least use their Iridium plugs
scrap the obsolete obdII scaner and ged a CAN to look at things from the past as well as the present and on into the future!
