DIY: 2005+ tail light on 2001-2004 W203 sedan
Old Feb 21, 2008 | 12:56 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
well, finally decide to get my 05 tail light working properly with the running light and the rear fog light.
The connector is a W211 part actually. If you already have the 05 tail light cover and the bulb holder, you will need the following
part # 2115450328 (the connector) you would need two
part # 0155450426 (the metal pins) you only need two if you know how to take the old ones out. IF you are lazy like me you will need total of 13 pins.
here's how you ID what each wire does.
Driver side:
Brown = ground (pin #6)
blk/grey = running light (pin #7 and pin #1)
blk/white = turn signal (pin #5)
blk/red = brake light (pin #4)
grey/blue = reverse (pin #3)
wht/green = rear fog (pin #2)
Passenger side:
red/grey = running light (pin #7 and pin #1)
green/blk = turn signal (pin #5)
black = brake (pin #4)
grey/yellow = reverse (pin #3)
Driver side:
connector (never mind the exposed wire, gotta redo'em later)
the connector from the front numbered left to right for the pins (7-1). Note the rib part should point upward.
Passenger side:
only 6 pin is needed since there's no fog light on this side.
the connector from the front. again, numbered 7-1, but NOTE the rib part should be facing down when you plug it into the passenger light bulb housing.
here's the end result
running light
fog light on
Old Feb 21, 2008 | 12:58 AM
mig888's Avatar
EVE
I got to see this hands-on . Very quick and painless if you any other of you guys need this for the updated look! Yeeeeeeeeeeeeeea ;D.
Old Feb 21, 2008 | 01:14 AM
kcheng86's Avatar
03 c320
awesome DIY
Old Feb 21, 2008 | 01:21 AM
e1000's Avatar
a quarter mile at a time
looks great Frank!
Old Feb 21, 2008 | 01:25 AM
Mu9enx's Avatar
01' C32o
pics asap! thanks for the writeup, now all drex has to do is put it in the stickies
Old Feb 21, 2008 | 04:31 AM
JERU107's Avatar
2002 Mercedes-Benz C240 sedan
nice job.. looks great. it's now on my list of mods
Old Feb 21, 2008 | 06:04 AM
C320 UK's Avatar
2002 C320 (full AMG styling) - Brilliant Silver / Ash Leather (Orion Grey)
Looks good, well done! Keen to see what the pin-outs need to be. I originally planned to do it the way you did by changing the connectors on my exisitng loom. I bought the 7 pin 211 part no connectors but wimped out so I bought a new rear loom and replaced the loom.
Do you get any malfunctions displayed in your cluster?
However, I believe the way I did it may need star coding. At present my 2005+ lights work perfectly but I only have one running light each side (just as before I upgraded). Just hope my rear SAM cab be enabled for dual running lights.
Old Feb 21, 2008 | 10:57 AM
mig888's Avatar
EVE
We had no malfunctions come up after mapping the wiring...
Old Feb 21, 2008 | 11:14 AM
kevblah's Avatar
E90 M3
wow awesome! i just now realized that on the 05 lights, the whole bottom row is lit
Old Feb 21, 2008 | 08:37 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the ghetto-fied connector pic is up...updated which wire goes where.
basically even with you changed the loom there's no power going into the inner running light, so you still have to splice the original running light wire. You should PM Sunil or Steve to find out, but I do not think you can.
Old Feb 21, 2008 | 11:08 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Great job on this, Frank.
Maybe I was subjected to shock therapy in a past life, but messing with the electrics gives me the *******.
Can I trade you a radiator installation for your tail lamp expertise?!
Old Feb 22, 2008 | 01:26 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
niiiiice Frank! thanks for the detailed DIY!
this is now in the DIY Sticky up top...
Old Feb 22, 2008 | 01:40 AM
rlee02135's Avatar
2004 C32 ///AMG
great DIY Frank!
Old Feb 22, 2008 | 01:53 AM
mig888's Avatar
EVE
!!! - Damn, what can I trade haha.
Old Feb 22, 2008 | 03:38 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
of course I'll need to find a behr radiator tho...lol
Old Feb 22, 2008 | 03:40 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
a DIY engine cover? lol
Old Feb 22, 2008 | 09:32 AM
mig888's Avatar
EVE
How about Frank and I set up a splinter session and I'll go hands on this mess...regardlesss of whatever radiator etc, I too am starting to fall victim to the transmission shiftiness.. . Suds and lunch will be involved.
Old Feb 22, 2008 | 12:17 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Old Feb 22, 2008 | 12:26 PM
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Nice, Frank.
Old Feb 22, 2008 | 04:58 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by drexappeal
Nice, Frank.
sell them s-class lights and join the oem group...LOL
Old Feb 22, 2008 | 05:02 PM
nlpamg's Avatar
oem group ftmfw! mj may be joining the oem group soon too... (or at least oem look)
Old Oct 3, 2008 | 06:12 PM
dac086's Avatar
2003 c320
Has anybody that did this have any issues? I tried to wire both parking lights and I get some burning smell because the wiring has some metal below that is melting the plastic that wraps around all the wiring for the bulbs. I just wired one of the parking lights and have no problems with the burning. Also is the inner parking light supposed to be much dimmer than the outer light? That is what I am getting when I wired them up.
Old Oct 3, 2008 | 06:33 PM
e1000's Avatar
both parking lights should be the same brightness, unless you pull out your light switch 2 positions to turn on the rear fog lamp.
Old Oct 3, 2008 | 06:49 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
there shouldn't be any thing melting. do you have the 05+ tail light and bulb holder?
if you only used the 04 bulb holder the wattage of the rear foglight bulb is different and that might be your source of smell.
Old Oct 19, 2008 | 10:42 PM
dac086's Avatar
2003 c320
i do have the 05 bulb holder. here are some pics
Attached Thumbnails DIY: 2005+ tail light on 2001-2004 W203 sedan-img_0994.jpg   DIY: 2005+ tail light on 2001-2004 W203 sedan-img_0995.jpg   DIY: 2005+ tail light on 2001-2004 W203 sedan-img_0996.jpg   DIY: 2005+ tail light on 2001-2004 W203 sedan-img_0997.jpg   DIY: 2005+ tail light on 2001-2004 W203 sedan-img_0998.jpg
DIY: 2005+ tail light on 2001-2004 W203 sedan-img_0999.jpg
