Front LED amber blinkers are GO!!!!!!!!
Old Mar 2, 2008 | 02:16 PM
e1000's Avatar
a quarter mile at a time
Originally Posted by goliath27
exactly what I'm saying.
Great Job E, Think these bulbs would work on my car without warnings?
ALi
they'll work if you connect the resistors like I did. I used 25W 6.8ohm resistors.
Old Mar 2, 2008 | 02:23 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
nice eric...
i wanna see it in person next weekend!
what's next? LED fogs and LED low-beams?
Old Mar 2, 2008 | 02:29 PM
e1000's Avatar
Originally Posted by MJ50
nice eric...
Belive it or not my fog light bulbs pre-date my car I had them on my Accord before I used them on my fogs. They don't sell them anymore though. They're FET CATZ Galaxy white bulbs.
When are you going to do your tails!?
Old Mar 2, 2008 | 02:32 PM
e1000's Avatar
Originally Posted by andy_meng1024
I also like white turn signals and have them on my car. Did anyone find out how to change the side LEDs to white yet?
I bet I could solder some different LED's in there. Wouldn't be that hard. You can find some nice LED's at digikey for cheap too.
User110's Avatar
2003 Cl 500
Soldering technique? like the Plate Lights I did? or something else?
ALi
Old Mar 2, 2008 | 02:35 PM
e1000's Avatar
ALi
You can tap the stock wiring like you did for your trunk. The way I did it was to drill a small hole into the plastic piece that holds the bulb into place. I ran some wire through the hole and soldered it to each of the metal prongs that touch the housing for the electrical current.
Old Mar 2, 2008 | 02:41 PM
  #32
User110's Avatar
2003 Cl 500
ooooo, PLEASE tell me you got a pic, I'd like to see that.
ALi
Old Mar 2, 2008 | 02:46 PM
  #33
e1000's Avatar
ALi
I didn't. Why do I get the feeling I'm going to have to pop my hood sometime today.
Old Mar 2, 2008 | 03:55 PM
  #34
User110's Avatar
2003 Cl 500
PRETTY PRETTY PLEEEEEEEASE!!!!!
ALi
Old Mar 2, 2008 | 04:08 PM
  #35
krnboy817's Avatar
c230
hey can you please show us the pics of the bulbs with your resistors on them trying to figure it out but... would be a lot of help if you show some pics
thanks
Old Mar 2, 2008 | 04:57 PM
  #36
User110's Avatar
2003 Cl 500
thanks
Ya, What he said
ALi
Old Mar 3, 2008 | 03:57 AM
  #37
andy_meng1024's Avatar
2003 SL55, 2010 C63
Andy, you using the same bulbs as Eric for the signals?
ALi
I have regular bulbs not the LEDs for turn signals so probably not the same.
Old Mar 3, 2008 | 04:00 AM
  #38
2003 SL55, 2010 C63
1157 is the same as 7507 except for the little metal nubs on the bottom of the bulb. 1157 has them 180 degrees from one another but 7507 has them offset a little bit. There are a lot more choices for 1157 bulbs so i just cut off one of the metal nubs.
You cut those out? Do they feel loose since those metal nubs are supposed to held the bulbs in place?
Old Mar 3, 2008 | 10:33 AM
  #39
e1000's Avatar
they feel a little loose. You only cut one not both. You still need something to keep the bulb in
Old Mar 3, 2008 | 04:18 PM
  #40
e1000's Avatar
sorry guys, just found out this morning that I have to be on a plane by 6PM. No pics until next week.
Old Mar 3, 2008 | 05:56 PM
  #41
User110's Avatar
2003 Cl 500
F Work, Go take a PIC!!!!
ALi
