Need help deperately...tires are rubbing TEIN's with 19" MRR's
TEIN Basic CO's
MRR GT1's 19x8.5 et35 front
General 235/35-19
I just finished installing the coilovers, put on the new tires and wheels, and the inside of the tire is hitting the bottom coil spring. In fact, the wheel won't even seat up against the brake hub, there is about a .050" gap because the tire is hitting the spring. Just for kicks, I put back on the 17" OEM 5 spokers and they clear...sort of....but not enough to make me feel comfortable driving.
I know there are guys running these rims on this car with no problems, so what gives? Are the coilovers installed wrong?
This pic shows the mark on the bottom of the spring where the tire was hitting.
On this pic, is the strut supposed to be about .25" off center?
And finally, is there supposed to be a gap between the strut hold down clamp and the tower?
Any help is appreciated.
The other thing is that its hitting the coilover significantly....like around 0.500" gap between the wheel and the rotor face. So my fear is that even with a 12-15mm spacer, it will just barly clear....or it might not.
I can't believe this is happening. I spent 2 months reading through hundreds of pages on this forum and there are a ton of guys running et30 and et32 with TEIN's with 235's with the car slammed and no problems.
The wheels clear the brakes, so that isn't a problem. i did my homework there.
what else can i do? switch to a 225 series tire combined with a 10mm spacer maybe?
Realistically, you should have an offset of 27 or 28 to clear coilovers and you have an offset of ET 35 up front and you also have 235 wide General wheels.
Your tires probably dont have rounded side walls and its generally difficult to run tires wider than 225 w/o rounded side walls. You could find tires w/ rounded side walls (Im not quiet sure which ones, I think Toyo t1rs are rounded though) to help the situation if you want to keep the 235 up front, but you are going to have to lower your offset at least by 7 mm (IMO). Id go 8 if that was an option :x
I think there are plenty of people who use these same wheels and with tein basics. Either you havent read or you missed ALOT of their posts about what they used to make their setups work. The aftermarket wheel thread has nearly every combo of suspension + wheel size/width imaginable and some details if they rub or not.
So:
1) should I go 8mm or 10mm spacer and keep the 235's or
2) should I go 225's (sell the brand new 235's) and get a 5mm spacer?
Don't do the 10mm spacer. Lowering your offset excessively will result in excessive rubbing of your plastic linings within your wheel well when you turn from lock to lock.
Going to a rounded 235 in the front, like T1R's would require new rears as well....its bad enough i'm going to lose money on the fronts when i sell and switch to 225's, so changing all four tires isn't an option.
I think I'll go 8mm with the 235's and see what happens, if it clears, see if i'm comfortable with the height. if there's still an interference, i'll switch to 225's. any other advice?
Go back to the wheel thread and look at the amount of people that listed their set-up with Tein's and for offset they said
Its ridiculous that people don't know thier offset. Let's take one of your posts for example. This is what you listed:Brand: HRE
Style: 441R
Color: silver face, polished lip
Offset: not sure, but they clear the AMG brakes by a sliver and there's plenty of clearance to drop my c/o's more!
Tire: Pirelli P-Zero M+S 225/40/18 & 255/35/18
Suspension: TEIN Basic coilovers
Now, you tell me how reading what you wrote there i'm supposed to extract that an et35 won't fit...yet everyone says "search"
I've read the first 10 pages in detail just tonight...again...and I saw a guy running et35 with a 16mm spacer and his fronts do not stick out, yet I read where Frank W said that anything under 24 you will stick out. I also read that 27-28 is ideal with Tein's, yet there are guys here running 30 or 32 with thier cars very low with no rubbing.
I'm just trying to get some help here...there's too many conflicting stories with these set-ups....and what works for one guy doesn't work for another.
All I'm trying to figure out now is what spacers I should get, 8mm or 10mm (8's will be custom) and should I switch to 225's from 235's? It really shouldn't be this hard.
lol...rounded sidewalls aren't an option becuase I'm not spending another $800 on 4 tires and selling mine for a $200 loss. pick another option
btw...no standard 8mm adapter exists. there is a site called wheeladapter.com where they make any size you want...maybe that's what you were referring to earlier...
Style: 441R
BUT Blake isnt at fault, HRE's do not put offsets on wheels as they are custom made.
like I suspected you have the front coilover WAY too low. the perch sitting all the way on the bottom means the front tires are tucking inside the fender. take a picture of it with the wheels on. I'm pretty sure i'm right.
with my ride height (see my sig) i'm on the 9th turn from the bottom up. your pic shows at 1st or 2nd turn. that's at least 10mm lower than mine. it just won't work. you need to raise it up. I'm on the 18" wheels with 225/40 which makes the gap bigger since the tire diameter is slightly smaller than the 235/35.
Good luck...
No...I admit that I was in error and that i just found the 27-28mm suggested fit for coilovers AFTER my stuff was ordered, but didn't want to jump the gun until i installed it. i was more concerned about brakes than anything else...since there are far more problems with brake clearance than there are with coilover clearance.
i'm kinda surprised at you actually...i've read hundreds of posts by you and see how highly regarded you are on this forum, and provide very informative and knowledgeable information. yet on my post, you chose to offer two comments that were both sarcastic and non-informative. thanks for the attitude and all your help.
