Tein Basic Ordered, Lip question
Old Mar 18, 2008 | 01:06 PM
Benzo0573's Avatar
2007 C230 Sport
So i just ordered my coilovers last night, i was wondering if i am still going to be able to tuck the front even with the carbon lip, any input or suggestions i appreciated, thanks!
Old Mar 18, 2008 | 01:21 PM
jfabes's Avatar
'07 GTI & '04 M3
while that may be a valid concern (i don't know because i don't have that lip), you may also want to look into getting your tires/wheels to fit with the coilovers and that low, tucked look.
my 19's rubbed my TEINs so i had to switch to a 225 tire with a 5mm spacer in order to get it to clear and ride low, but even at that, im at about the 4th thread from the bottom....and it just barely clears. the 17" oem sport rims did not clear and i had to raise it up to oem height so i could drive it until i got everything sorted out.
so its a delicate balance, you want it low so you can tuck and to do that, you will probably need spacers with those oem rims. on the other hand, you can't go out too far with spacer for a "tucked" situation or you will rub the inside of the fender liner on the outer side.
Old Mar 18, 2008 | 01:30 PM
outaurleague's Avatar
w211 e500
yeah your going to have to play with tire and rim sizes a lot.
Old Mar 18, 2008 | 01:52 PM
Benzo0573's Avatar
2007 C230 Sport
so basically i need spacers because im not doing wheels anytime soon, i love my 07 wheels so where can i buy spacers for my front and rear to push the rim out a little more
Old Mar 18, 2008 | 03:28 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
I think it'll be too low with lip and risking of messing up the lip when you have dip . I raised mine to no gap just to be on the safe side.
SlvrC230SS's Avatar
H&R
Old Mar 18, 2008 | 03:37 PM
Benzo0573's Avatar
2007 C230 Sport
Originally Posted by SlvrC230SS
H&R
i have no idea what size to get. anybody know what i should get with the stock wheels for front and back?
Old Mar 18, 2008 | 03:47 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
5mm front, 10mm rear?
Old Mar 18, 2008 | 04:48 PM
Mu9enx's Avatar
01' C32o
i also have the same concern, except i hvae 18's. damn!
