Rattle and squeak!!!?! what is it?
Old Apr 26, 2008 | 09:25 PM
Rzrlp's Avatar
2005 C230K
Ok, so tuesday after our photo shoot someone pointed out that it sounded like something was loose under the hood as there was a rattling sound, the next day I really started to hear it. When I start the car, that first split second u hear a rattle, then nothing, runs quiet and smoth, but, when the car is still cold and you have your foot on the brake, and **** gear into either drive or reverse, you get a loud rattleing and you also hear a squeaking, this only happens when the car is in drive or reverse and at a complete stop, the second you start moving, even a crawl, it goes away. Once the car gets warmed up, say 5 mins, its gone, no sound or nothing. also smell some fuel, and that goes away also. No leaks anywhere as I can see, Moosejaw also looked at it with me, we see nothing loose or leaking! any help please!
Old Apr 27, 2008 | 12:53 PM
GINO-ESC's Avatar
Its a lower pully. I have the same year car and had the problem about two-three months ago. If you are still under warrantee, get it to the dealer.
Old Apr 27, 2008 | 01:18 PM
Beaver's Benz's Avatar
'05 C230K SS Granite Grey Metallic
I am having a very similar if not the same problem and I have 49,980 miles, so I wouldn't even have 20 miles to get to the dealer for warrantee work. Please keep us posted if you get it fixed and if it is the lower pulley.
Old Apr 27, 2008 | 01:26 PM
Rzrlp's Avatar
2005 C230K
but if it was a pulley or something, why would it stop rattling once the car warms up? it doesnt continuously do this. any idea how much it should cost to fix? i am out of warranty
Old Apr 27, 2008 | 03:24 PM
GINO-ESC's Avatar
ok, found the service invoice. The problem you are describing is 100% exactly what I had.
This is what the invoice reads:1 271-200-02-70 TENSION ROLL
51 GF
133200 BELT TENSIONER - FOR SINGLE BELT DRIVE, R&R / REPL.
INSPECTED VEHICLE HEARD SQUEAK / RATTLE NOISE AT START UP, LUBED BELT NOISE STILL PRESENT, R/R BELT AND STARTED
NOISE GONE, PUT BELT BACK AND TESTED MORE, FOUND WHEN VEHICLE FIRST STARTED TENSIONER MADE A NOISE WHEN FIRST LOADED, R/R TENSIONER AND PUT BELT BACK STARTED AND NO MORE NOISE HEARD
HOPE THIS HELPS
Old Apr 27, 2008 | 03:45 PM
Rzrlp's Avatar
2005 C230K
great thanks.
Old Apr 30, 2008 | 09:11 PM
polarbexar's Avatar
Veteran: Air Force
2025 Mazda CX70 Turbo S, 2015 G550
I've got the same noise. I'm going in on Monday to check it out I'm at 67K so we'll see what they say. This will be my first expirience with the extended warranty.
Old May 1, 2008 | 12:03 AM
Andonixxx's Avatar
SL450
I have the same noise on my girlfriends car 05 c230 she doesnt have factory warranty anymore anybody knos how much will it cost to replace?????
Old May 5, 2008 | 02:56 PM
Rzrlp's Avatar
2005 C230K
well i just dropped off car now at my independent mercedes guy, he wants 70 to diagnose, and will put that to cost of repair work.
Old May 5, 2008 | 11:40 PM
Andonixxx's Avatar
SL450
i went last week to do the recall they wanted 125 to do an estimate I ran away
Andonixxx's Avatar
SL450
let me know what they say thanksss
Old May 6, 2008 | 10:16 AM
Rzrlp's Avatar
2005 C230K
well i just called him, he is still trying to figure it out, says its between the supercharger and AC condensor. how can it be supercharger? it is only while i am in drive and reverse, only upon start up when engine is COLD, only under like 1000 rpm, and only for like 3 mins, once engine is warm, its gone!
Whats this i read about some 12$ hose replacement? i cant find the service bulliten about that, never got anything in mail either. Could this be a culprit?
Old May 6, 2008 | 03:56 PM
Rzrlp's Avatar
2005 C230K
Ok, looks like its actually the ac compressor. when the ac is off, the belt barely rattles, when the ac is on, it shakes a lot! I am going to make an appointment with a different dealer in the area, get a 2nd opinion and see if they will cover it under grace period warranty, car is barely 3 yrs old.
Old May 10, 2008 | 01:39 AM
shizo's Avatar
2002 C230 Coupe
Thanks man, I have the same thing going on too. Just for clarification, did the dealer replace the tensioner or just tighten it? Not sure what R/R stands for...
Old May 11, 2008 | 01:12 AM
GINO-ESC's Avatar
It was replaced. I had just shy of 50,000 miles when the problem occured. Similar to the mileage of all those people with the problem. Havent had a problem since.
Old Jul 31, 2010 | 10:19 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
^ Damn, thanks for starting this thread. Time to revive it. My car just started having this problem. My friends think the transmission is about to blow or something. It's annoying for sure but from what it sounds like it's not critical to have it replaced.
Not sure if it's tied to the AC though? Will check it out later today.
R/R = Remove and Replace.
Old Jul 31, 2010 | 04:11 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Post up what it turns out to be. Is it a tensioner or the A/C compressor the rest of the thread is kind of confusing.
