Should I use Valvoline SynPower 5w-30 or 5w-40? (Definitive Thread)
What should i use, a higher vicosity? Change the oil brand? or add one of those syntethic oil stabilizers?
I do not have the owners manual , that's one of the reasons im asking.
Last edited by LinDenKid; Jul 22, 2009 at 09:21 AM. Reason: because im a no-lengual person , no english , no spanish.
Good luck
Good luck
The rattle after standing is quite common, & likely the timing chain rattling before the oil pressure comes up & the hydraulic tensioners kick in properly. Usually means new chain & tensioners. I've seen some reports on pulley rattle on the M111 as well but this should not be affected by standing..
Suggest you contact C230 Sport Coup - he has fitted an oil catch tank & could give you some advice on oil coming through the inlet system.
Good luck
Good luck
I have a quick question with an upcoming Service B I am going to perform on my newly purchased 2006 C280 4MATIC. I have been reading the forums like a mad man and think I am pretty well coached as to what I am required to do and how to go about the various maintenance items (thanks to Service B sheet found on this forum and # of DYI threads). The only issue leaving me stumped is whether I can use Valvoline SynPower 5w-30 or 5w-40. At the moment Schucks (aka PartsAmerica) has 1QT of the above oil(s) for .99 AR. Unfortunately Schucks does not carry the MST version as prescribed by Mercedes -- Found Here. From what I can see the Synpower MST has a 11.7 visc@100C versus the regular Synpower has 10.7 visc@100C.
What adds to my confusion, according to Valvoline's product info page ((Found Here), the SynPower 5W-40 is pending OEM approval for MB 229.51 which has closer specs to Mobil 1 0W-40 such as 14.5 visc@100C versus 14 visc@100C and 89 visc@40C versus 78.3 visc@40C, respectively. Mobil 1 details Found Here. So that makes me think the 5w-40 is a better choice.
I live in Anchorage Alaska where the temps range from ~80s in the summer to -20 in the winter. I do not want to ultimately do harm to my engine nor void my warranty. What do you guys advise?
Thanks in advance!
Use Valvoline Full Synthetic 5 W 30. It has never steered me wrong.
Thanks in advance!
Where I shop now for OIL in CA. Valvoline Full Syn 5W30/OW20 is 2 bucks more for a 5 quart jug than Mobil 1 5W30/OW20, if you can get ANY Valvoline product for a Dollar buy it man...Valvoline is super oil!
http://www.valvolineeurope.com/english/products/engine_oils/synpower/cid(805)/synpower_5w-40/product-information
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Formula_M_5W-40.aspx
I live in Lebanon and prior to this, I was using Fuchs TITAN Supersyn LONGLIFE 5W-40 from the dealership which is supposed to be a 229.5 oil and should last 21,000 km - 13,000 miles when used with a fleece filter (I use MANN).
However, when I used that oil for 10,000 km - 6,000 miles, my mechanic and I noticed sludges in the engine and went back to a 5-6,000 km change interval or 3,100 miles.
As I did some researched, I learnt from a local high-level expert that this Fuchs TITAN Supersyn LONGLIFE is made in the Gulf (most probably United Arab Emirates) and that its quality is not as good as the same oil made in Europe. He was specific about some lab processes not being done correctly and enough for oil to last 13,000 miles like Mobil 1 or other 229.5 oils.
So, because of the above, I decided to try out other 229.5 products available in my country and I came across Valvoline products. The story here is that 229.5 lists Valvoline SynPower HST 5W-40 where I could only find Valvoline SynPower MST 5W-40.
I did some further research on MST vs HST, but could not get enough information on whether it would still be better than the Fuchs TITAN crap that I've been forced to using. Any advice on this would be highly appreciated.
Other 229.5 oils available in my country are the ELF Evolution 900 FT 5W-40 and MOTUL 8100 X-cess 5W-40 (too expensive).
Looking forward to your feedback.
Thank you.
Latest 229.5 listing dump.
Last update: 04/06/2017
Productname 0W-30 0W-40 5W-30 5W-40 Principal
Mercedes-Benz Genuine Engine Oil MB 229.5 x Daimler AG, Stuttgart/Deutschland
Mercedes-Benz PKW-Synthetic Motorenöl MB 229.5 x Daimler AG, Stuttgart/Deutschland
AMG High Performance Engine Oil x Daimler AG, Stuttgart/Deutschland
MB 229.3/229.5 Motorenöl A 000 989 87 01 x Daimler AG, Stuttgart/Deutschland
MB 229.5 Motorenöl A 000 989 83 01 x Daimler AG, Stuttgart/Deutschland
77 MOTOR OIL MP 5W-40 x 77 Lubricants B.V. , DORDRECHT/THE NETHERLANDS
8100 X-cess MOTUL SAE 5W40 x Motul , AUBERVILLIERS CEDEX/FRANCE
ADDINOL ECO LIGHT x Addinol Lube Oil GmbH, Leuna/Deutschland
ADDINOL SUPER LIGHT 0540 x Addinol Lube Oil GmbH, Leuna/Deutschland
ADDINOL SUPER POWER MV 0537 x Addinol Lube Oil GmbH, Leuna/Deutschland
AeroShell Oil Diesel Ultra x Shell International Petroleum Company, LONDON/UNITED KINGDOM
AKTUAL FULLY SYNTH 5W-40 x PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALY
Alpine RS 0W-40 x Mitan Mineralöl GmbH, Ankum/Deutschland
AMSOIL EUROPEAN CAR FORMULA Full SAPS 5W-40 x Amsoil Inc., Superior, Wisconsin/USA
ARAL HIGH TRONIC M SAE 5W-40 x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SUPER TRONIC G x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SuperSynth x Aral Aktiengesellschaft, Hamburg/Deutschland
arexons 3X B4 x PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALY
Asahi Synthesis SN 5W-40 x Beijing Asahi Cliane Petrochemical Co. Ltd., Beijing/P. R. of CHINA
ASTRIS MAGIS SAE 5W-30 x Astris S.A., GIORNICO/Schweiz
ASTRO BOY X-PRO 5W40 x Kawada Holdings Co. Ltd., Hong Kong/HONG KONG
ATLANTIC SYNTHECH ULTRA SUPER 5W-30 x Atlantic Grease & Lubricants FZC, Sharjah/UNITED ARAB EMIRATES
ATLANTIC SYNTHECH ULTRA SUPER 5W-40 x Atlantic Grease & Lubricants FZC, Sharjah/UNITED ARAB EMIRATES
Austro Engine Aero x Liqui Moly GmbH, Ulm/Deutschland
AVENO FS Excellence 0W-40 x Deutsche Ölwerke Lubmin GmbH, Lubmin/Deutschland
AVENO FS Select 5W-30 x Deutsche Ölwerke Lubmin GmbH, Lubmin/Deutschland
AVIA Dynetic-HS 5W-40 x Avia Mineralöl-AG, München/Deutschland
AVIA SPS PLUS x AVIA Genossenschaft Schmierstoffe, ZÜRICH/Schweiz
AVIASYNTH 5W-40 x Avia Mineralöl-AG, München/Deutschland
AVIATICON UNIQUE DC 5W-30 x Finke Mineralölwerk GmbH, Visselhövede/Deutschland
Biloxxi 5W-30 x MCC Trading Deutschland GmbH, Düsseldorf/Deutschland
BIZOL T TECHNOLOGY 5W-40 x Bita Trading GmbH, Berlin/Deutschland
Blasol PSP 5W40 x Blaser Swisslube AG, Hasle-Rüegsau/Schweiz
Blaze Racing HTP x Petron Corporation, Mandaluyong City/PHILIPPINES
bp superV Plus 5W-40 x BP p.l.c., LONDON/UNITED KINGDOM
bp Visco 5000 5W-30 x BP p.l.c., LONDON/UNITED KINGDOM
Caltex Havoline ProDS Fully Synthetic x x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Castrol EDGE 0W-30 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge 0W-40 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE 5W-30 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge 5W-40 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional A3 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional A3 0W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge Professional A3 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE PROFESSIONAL A3 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Supercar 0W-40 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Magnatec Professional A3 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol MAGNATEC STOP-START 5W-30 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol MAGNATEC STOP-START 5W-40 A3/B4 x Castrol Limited, SWINDON/UNITED KINGDOM
CEPSA AVANT 5W40 SYNT x CEPSA Comercial Petróleo, S.A.U., Madrid/SPAIN
CEPSA GENUINE 5W40 SYNTHETIC x CEPSA Comercial Petróleo, S.A.U., Madrid/SPAIN
CHAMPION ECO FLOW 0W40 FE x Champion Chemicals N.V., BELGIUM/BELGIUM
CHAMPION LIFE EXTENSION 5W40 HM x Champion Chemicals N.V., BELGIUM/BELGIUM
CHARGER XTREEM x Bahrain Petroleum Company, Awali/KINGDOM of BAHRAIN
Chevron Havoline Pro DS Full Synthetic x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Chevron Havoline Synthetic Motor Oil x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
CONCEP-TECH CX 5W-40 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
CONCEP-TECH VS 0W-40 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
CYCLON MAGMA SYN ULTRA x LPC S.A., Aspropyrgos/GREECE
Divinol syntholight 0W40 x Zeller+Gmelin GmbH & Co. KG, Eislingen/Deutschland
Divinol syntholight MBX SAE 5W-30 x Zeller+Gmelin GmbH & Co. KG, Eislingen/Deutschland
Divinol syntholight Top 5W-40 x Zeller+Gmelin GmbH & Co. KG, Eislingen/Deutschland
EKO MEGATRON SYNTHETIC 5W-30 x Hellenic Fuels and Lubricants Industrial and Commercial SA (EKO ABEE), Marousi, Athens/GREECE
ELAION F50 plus x YPF S.A. Lubricantes & Especialidades, Buenos Aires/ARGENTINA
ELF Evolution 900 FT 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
ELF Evolution 900 FT 0W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
ELF Evolution 900 FT 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
eni i-Sint 0W-40 x ENI S.p.A. - Refining & Marketing Division, ROM/ITALY
eni i-Sint PC 4AM 5W-30 x Eni S.p.A., Refining & Marketing Division, ROME/ITALY
eni i-Sint PC 4AM 5W-40 x ENI S.p.A. - Refining & Marketing Division, ROM/ITALY
ENOC PROTEC X-TREME 5W-40 x ENOC International Sales L.L.C., DUBAI/UNITED ARAB EMIRATES
EUROLUB SYNT M 5W/40 x EUROLUB GmbH, Eching/Deutschland
Fastroil Premium Plus SAE 5W-40 x HILL Corporation, Shymkent/KAZAKHSTAN
Fastron GOLD x PERTAMINA , Jakarta/INDONESIA
Feu Vert 5W40 100% SYNTHÈSE x Feu Vert, ECULLY CEDEX/FRANCE
FK EURO 0W-40 x BAN HON INTERNATIONAL CO., LTD., Lukang Township, Changhua County/TAIWAN R.O.C.
FK EURO 5W-40 x BAN HON INTERNATIONAL CO., LTD., Lukang Township, Changhua County/TAIWAN R.O.C.
Fuchs TITAN Supersyn 229.5 SAE 5W-40 x FUCHS PETROLUB SE, Mannheim/Deutschland
FUCHS TITAN Supersyn Hi-TBN SAE 5W-40 x FUCHS PETROLUB SE, Mannheim/Deutschland
Fuchs TITAN Supersyn LONGLIFE 5W-40 x Fuchs Petrolub AG, Mannheim/Deutschland
Fuchs TITAN Supersyn LONGLIFE SAE 0W-30 x Fuchs Petrolub AG, Mannheim/Deutschland
Fuchs TITAN Supersyn LONGLIFE SAE 0W-40 x Fuchs Petrolub AG, Mannheim/Deutschland
G-Energy F Synth 5W-30 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
G-Energy F Synth 5W-40 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
GALP FORMULA ENERGY 0W40 x Petróleos de Portugal, Petrogal S.A, Lissabon/PORTUGAL
GALP FORMULA ENERGY 5W40 x Petróleos de Portugal, Petrogal S.A, Lissabon/PORTUGAL
GALP FORMULA M-FS 5W40 x Petróleos de Portugal, Petrogal S.A, Lissabon/PORTUGAL
GAZPROMNEFT PREMIUM N 5W-40 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
GEP Rayspeed Economy 5W-40 x Lubritech Limited, Jiangmen/P. R. of CHINA
GEP Rayspeed Syntherm 0W-40 x Lubritech Limited, Jiangmen/P. R. of CHINA
Gulf Formula GMX x Gulf Oil International, London/ENGLAND
Gulf Formula GX x x x x Gulf Oil International, London/ENGLAND
GulfTEC EURO SAE5W-40 Full Synthetic x Reliance Fluid Technologies LLC, Niagara Falls/USA
HI-REV 9140 API SN x POSIM Petroleum Marketing SND BHD, Shah Alam/MALAYSIA
HIGH STAR SAE 5W-40 x Addinol Lube Oil GmbH, Leuna/Deutschland
IDEMITSU ZEPRO EURO SPEC x Idemitsu Kosan Co., Ltd., Tokyo/JAPAN
INA Ultra Sint 5W-30 x INA MAZIVA Ltd., Zagreb/CROATIA
INFINITI MOTOR OIL 5W-40 x Idemitsu Kosan Co., Ltd., Tokyo/JAPAN
IPIRANGA F1 MASTER SINTETICO 5W30 229.5 x IPIRANGA PRODUTOS PETRÓLEO S.A, Rio de Janeiro/BRAZIL
JB GERMAN OIL Longlife P-5 5W-40 x JB German Oil, Wittenburg/Deutschland
Kendall GT-1 FULL SYNTHETIC EURO SAE 5W-40 x Phillips 66 Company, Bartlesville, OK/USA
KunLun TianRun 5W-40 x PetroChina Lubricant Company, Beijing/P. R. of CHINA
KunLun TianRun KR9-T x PetroChina Lubricant Company, Beijing/P. R. of CHINA
LIQUI MOLY 5W-30 Leichtlauf High Tech LL x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY 5W-40 LEICHTLAUF HIGH TECH x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY Optimal Synth x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY PRO-ENGINE M900 x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY Special Tec LL x Liqui Moly GmbH, Ulm/Deutschland
Liquid Gold SYN-FLO LS x NSL OilChem Trading Pte Ltd, Singapore/SINGAPORE
longrun LONGT ULTRA x Beijing LongRunKaiDa PEC Product Company Ltd. , Beijing/P. R. of CHINA
LOTOS SYNTHETIC PLUS SAE 5W40 x Grupa Lotos SA., GDANSK/POLAND
LubriGold Full Synthetic 5W-40 x Warren Oil Company, Inc., WEST MEMPHIS, AR 72303-2048/USA
LUKOIL GENESIS 5W-30 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS 5W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS ARMORTECH 5W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS POLAR 0W-30 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS POLAR 0W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS POLARTECH 0W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS SPECIAL 5W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS SPECIAL POLAR 0W-30 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS SPECIAL POLAR 0W-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL LUXE SPECIAL 5w-40 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL LUXE SYNTHETIC x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL LUXE SYNTHETIC 5W-40 x OOO LLK-International, MOSCOW/RUSSIA
mabanol Xenon Alpha Stellar 5W-40 x Mabanol GmbH & Co. KG, Hamburg/Deutschland
MAG PRIMA EXTREME SAE 5W30 API SN x MAG LUBE L.L.C., Dubai/UNITED ARAB EMIRATES
master oil v-tec Premium 0W-40 x Interparts Autoteile GmbH, Stuttgart/Deutschland
megol Motorenoel High Condition x Meguin GmbH & Co. KG Mineraloelwerke, Saarlouis/Deutschland
megol Motorenoel Quality x Meguin GmbH & Co. KG Mineraloelwerke, Saarlouis/Deutschland
Midland synqron 0W-40 x Oel-Brack AG, HUNZENSCHWIL/Schweiz
miocar MX Syntra 5W-40 x Migros Genossenschafts Bund, Zürich/Schweiz
MISR PHOENIX x Misr Petroleum Co., Cairo/EGYPT
Mobil 1 0W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 Formula 0W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 Formula M 5W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 FS 0W-30 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 FS 0W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 FS 5W-30 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 New Life 0W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil 1 Turbo Diesel 0W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil SHC Formula M 5W-30 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil SUPER 3000 FORMULA M 0W-30 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil Super 3000 Formula M 5W-30 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil Super 3000 Formula M 5W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil Super 3000 X3 5W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil Super 3000 X4 5W-30 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil Super Formula M 0W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Mobil Super Formula M 5W-40 x Exxon Mobil Corporation, Spring, Texas/USA
Motor Oil MBP 5W-40 x Transnational Blenders B.V., BG DORDRECHT/THE NETHERLANDS
MOTOREX PROFILE M-XL 5W/40 x Bucher AG Langenthal, LANGENTHAL/Schweiz
MOTOREX TOPAZ SAE 5W/30 x Bucher AG Langenthal, LANGENTHAL/Schweiz
MOTOREX XPERIENCE FS-X SAE 0W/40 x Bucher AG Langenthal, LANGENTHAL/Schweiz
Motorsynth Ultra 5W-40 x Delek Industries Ltd., Lod/ISRAEL
MOTUL 8100 X-cess 5W-40 x Motul , AUBERVILLIERS CEDEX/FRANCE
MOTUL 8100 X-max 0W-40 x Motul , AUBERVILLIERS CEDEX/FRANCE
MOTUL 8100 X-MAX 0W30 12XIL x Motul , AUBERVILLIERS CEDEX/FRANCE
MOTUL EXPERT M 5W-40 x Motul , AUBERVILLIERS CEDEX/FRANCE
MOTUL H-TECH Prime SAE 5W40 x Motul , AUBERVILLIERS CEDEX/FRANCE
MOTUL J-01 Street 5W-40 x Motul , AUBERVILLIERS CEDEX/FRANCE
Motul Synergie Tech+ 5W40 x Motul , AUBERVILLIERS CEDEX/FRANCE
NATIONAL SPEEDX MAGNUM 5W/40 x Technolube LLC, Dubai/UNITED ARAB EMIRATES
Neste City Pro LL 5W-30 x Neste Markkinointi Oy, NESTE OIL/FINLAND
Nordlub V-Synto HM x NORDLUB Deutschland GmbH, Buxtehude/Deutschland
OEST GIGANT SPEZIAL SAE 5W-40 x Georg Oest Mineralölwerk GmbH & Co KG, Freudenstadt/Deutschland
OMV BIXXOL premium NT SAE 5W-40 x Prista Oil Holding EAD, RUSE/BULGARIA
PAZ Extreme PS 5W-40 x Paz Lubricants & Chemicals Ltd., HAIFA 31000/ISRAEL
Pennzoil Platinum Euro x x x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Pennzoil Ultra Euro x x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
PENRITE HPR 5 5W-40 x Penrite Oil Company Pty Ltd, DANDENONG/AUSTRALIA
PENTO HIGH PERFORMANCE 5W-30 x FUCHS PETROLUB SE, Mannheim/Deutschland
Pentosynth R 5W-40 x FUCHS PETROLUB SE, Mannheim/Deutschland
Performa Synthetic x PTT Public Company Limited, Chatuchak, BANGKOK 10900/THAILAND
Petromin Supersyn plus 5W40 x Petromin Oils, Jeddah/SAUDI ARABIA
PETRONAS Syntium 3000 E x PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALY
PETRONAS Syntium 3000 E 5W-40 x PETRONAS LUBRICANTS INTERNATIONAL, KUALA LAMPUR/MALAYSIA
PETRONAS SYNTIUM 7000 x PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALY
PHOENIX PXXTREME POWER 5W40 LL01 x Phoenix Lubricants Pty Ltd, Victoria/AUSTRALIA
Power Oil Syntec 0W-40 Racing x Power Oil e.K., Karlsfeld/Deutschland
Prista Ultra 5W-40 x Prista Oil Holding EAD, RUSE/BULGARIA
PULSAR CR x PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALY
Pzl Platinum European Formula Ultra x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Q8 Formula Excel Long Life 5W-40 x Kuwait National Petroleum Company, Kuwait/KUWAIT
QS Ultimate Durability European x x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
RAVENOL HCL SAE 5W-30 x Ravensberger Schmierstoffvertrieb GmbH, Werther/Deutschland
RAVENOL SSL 0W-40 Fullsynth CleanSynto x Ravensberger Schmierstoffvertrieb GmbH, Werther/Deutschland
RAVENOL SSO SAE 0W-30 x Ravensberger Schmierstoffvertrieb GmbH, Werther/Deutschland
RAVENOL VST VOLLSYNTH TURBO 5W-40 x Ravensberger Schmierstoffvertrieb GmbH, Werther/Deutschland
real,- Quality GSR 5W-30 x real,- Handels GmbH, Düsseldorf/Deutschland
REPSOL ELITE Common Rail 5W30 x REPSOL LUBRICANTES Y ESPECIALIDADES, S.A., MOSTOLES (Madrid)/SPAIN
REPSOL ELITE COSMOS HIGH PERFORMANCE x REPSOL LUBRICANTES Y ESPECIALIDADES, S.A., MOSTOLES (Madrid)/SPAIN
ROLF GT SAE 5W-40 API SN/CF x ROLF Lubricants GmbH, Leverkusen/Deutschland
ROWE HIGHTEC SYNT RS HC-D SAE 5W-40 x ROWE Mineralölwerk GmbH, Worms/Deutschland
Sasol Engine Oil Synthetic M 5W-40 x Sasol Oil (Pty) Ltd, RANDBURG/REPUBLIC of SOUTHAFRICA
Seanon YN9 SN 5W40 Gasoline Engine Oil x Seanon Petrochemical Co.,Ltd, Liuzhou/P. R. of CHINA
Shell Helix HX8 C x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra x x x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra Diesel x x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra E x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra Professional AB x x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra Professional ABB x Shell International Petroleum Company, LONDON/UNITED KINGDOM
SHIELD EURO-TECH x Phillips 66 Company, Bartlesville, OK/USA
Sinopec Justar J700U x Lubricant Company, Sinopec Corp., Beijing/P. R. of CHINA
SINOPEC 229.5 5W-40 x Lubricant Company, Sinopec Corp., Beijing/P. R. of CHINA
Sinopec Justar A3/B4-Y x Lubricant Company, Sinopec Corp., Beijing/P. R. of CHINA
Sinopec Justar J700F-Y-a x Lubricant Company, Sinopec Corp., Beijing/P. R. of CHINA
SPC SYN ACE SUPREME API SN x Singapore Petroleum Company Limited, SINGAPORE/SINGAPORE
Specialsynth G Gold 5W40 x PHI OIL GmbH, St. Georgen bei Salzburg/Österreich
SRS ViVA 1 ecosynth plus x SRS Schmierstoff Vertrieb GmbH, Salzbergen/Deutschland
SRS ViVA 1 Longlife x SRS Schmierstoff Vertrieb GmbH, Salzbergen/Deutschland
SRS ViVA 1 topsynth plus x SRS Schmierstoff Vertrieb GmbH, Salzbergen/Deutschland
Star synt S x ORLEN Deutschland GmbH, ELMSHORN/Deutschland
Statoil SUPERWAY 5W-40 x FUCHS PETROLUB SE, Mannheim/Deutschland
Svelt EURO 5W-40 x Japan Sun Oil Co..LTD, Tokyo/JAPAN
Swd Rheinol Primus CVS 5W-40 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
Swd Rheinol Primus CVS SAE 5W-30 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
Swd Rheinol Primus VS SAE 0W-40 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
SYNTHETIC POWER SAE 5W-40 x Alexandros Badas & SIA EE, Kiparrisi Lokridos/GREECE
TAMOIL SINT FUTURE PRESTIGE SAE 0W-30 x Tamoil Italia S.p.A., MILANO/ITALY
TAMOIL SINT FUTURE RACING x Tamoil Italia S.p.A., MILANO/ITALY
TD6201155 x PETRONAS LUBRICANTS INTERNATIONAL, VILLASTELLONE (Torino)/ITALY
TESLA POLARIS FS 1120 SAE 5W 40 x Tesla Technoproducts FZE, DUBAI/UNITED ARAB EMIRATES
Texaco Havoline Synthetic x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Texaco Havoline Ultra x x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Tor Hypersynth D 5W40 x De Oliebron, ZWIJNDRECHT/THE NETHERLANDS
TOTACHI PRO TOURING M 5W-40 x Totachi Industrial Co., LTD., Japan, Otaru/JAPAN
Total Quartz 9000 Energy 0W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz 9000 Energy 0W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz 9000 Energy 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz 9000 Energy 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz 9000 Energy RQ 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
TRIATHLON FORMULA LL x Adolf Würth GmbH & Co. KG, Künzelsau/Deutschland
Triathlon Premium SAE 5W-40 x Würth International Trading (Shanghai) Co., Ltd., Shanghai/P. R. of CHINA
Valvoline DURABlend MXL 5W-40 x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SynPower 0W-40 x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SynPower 5W-30 x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SynPower HST 5W-40 x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SynPower SAE 5W-40 x The Valvoline Company, LEXINGTON, KY/USA
Veedol Powertron Extra 5W-40 x Veedol International Limited, Glasgow/UNITED KINGDOM
VENOL SYNTHESIS HC-EC GOLD ACTIVE SAE 5W-40 x VENOL Motor Oil GmbH, Frankfurt (Oder)/Deutschland
Westfalen Gigatron 0W-40 x Westfalen AG, Münster/Deutschland
WMTEC MOTORENÖL SAE 5W-30 MF x WM SE, Osnabrück/Deutschland
WOLF ECOTECH 0W40 FE x Wolf Oil Corporation N.V., HEMIKSEN/BELGIUM
WOLF EXTENDTECH 5W40 HM x Wolf Oil Corporation N.V., HEMIKSEN/BELGIUM
YACCO VX 1000 LL SAE 5W-40 x Yacco SAS, ST PIERRE LES ELBEUF/FRANCE
YACCO VX1000 LL 0W40 x Yacco SAS, ST PIERRE LES ELBEUF/FRANCE
ZHONG HUA 1 SN 0W/40 x Beijing Zhonghua Petrochemical Stock Co., Ltd., Beijing/P. R. of CHINA
ZHONGHUA 5000# Synthetic Motor Oil x Beijing Zhonghua Petrochemical Stock Co., Ltd., Beijing/P. R. of CHINA
ZIC X9 5W-30 x SK Lubricants. Co., LTD., DAEJEON/Rep. of KOREA
ZIC X9 5W-40 x SK Lubricants. Co., LTD., DAEJEON/Rep. of KOREA
