Stock suspension adjustible!!?!??
Old Dec 9, 2002 | 05:09 PM
CarlssonPower's Avatar
2002 C240
My friend told me that in all Mercedez cars you can manually adjust (or cut?) a rubber part near the shock to adjust a little bit of the ride height. Do you guys ever heard about this?
Old Dec 9, 2002 | 06:06 PM
KWiK's Avatar
2002 C230 : 2007 C230
that's true on many models but for the W203 it only applies to the rear. do a search on "spring pad" for plenty of info.
Old Dec 10, 2002 | 10:55 AM
mdp c230k's Avatar
2002 c230k
There is a spring pad under the rear spring that can be changed from 5 to 20mm in steps of 5mm to adjust the rear height. There are different pads for each height that are noted by the number of dots on the pad, one dot=5mm two=10mm etc..
Old Dec 10, 2002 | 01:09 PM
jscavo's Avatar
w203
what is the stock thinkness from the factory? 40mm highest car height, 5mm lowest car height. rear end only
Old Dec 10, 2002 | 03:25 PM
eason's Avatar
W212 E63
I think the rear height good enough, if you lower the rear more and the front stays the same, it will look more ugly then stock.
Old Dec 10, 2002 | 03:41 PM
2002 C240
That is my problem now.. I lowered my car with H&R cup kit, the rear is okay, but I would like the front to be lowered more.... but according to the infos only the rear have spring pad....
Old Dec 10, 2002 | 08:58 PM
W0n6_3d4n's Avatar
C200K (w204)
Cut your front spring. I'm sure cutting one coil or less won't affect the ride that much
Old Dec 10, 2002 | 11:56 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
that's still the last thing u'd wanna do...
Old Dec 11, 2002 | 10:41 AM
mdp c230k's Avatar
2002 c230k
This is a very bad idea.
The are too many reasons to list why this should not be done, its redneck mechanics.
