H&R coilover rear perch top or bottom??
2002 c320 wagon
H&R coilover rear perch top or bottom of spring??
I just got H&R coilovers and there were no instructions. The mechanic installed the perch on the top which makes it impossible to adjust without taking the entire assembly apart. From what I've seen on the BMW's & VW's it seems like they have it on the bottom. It does not make sense that they would design so it's so difficult to adjust the height.
I'm going to call H&R on Monday but I need to know as soon as I can so I can make them redo it if they installed incorrectly.
2003 Ford F350-gone 2002 Mercedes C200 Kompressor 1998 Suzuki Vitara 1995 Mercedes C180-sold
Yeah I asked the same question, so did my mechanic, but you have it right! Make sure he removed the rubber mounts (cant think of the correct name) that hold the old springs in, otherwise your rear will never squat down as low as the front.
Phil
'09 A4 S Line
2002 c320 wagon
I called H&R and they told me you can adjust the rear height after coilover is installed but I don't see how that's possible. This sucks because the mechanic won't adjust the height again unless I pay for another hour of labor. I was hoping he did it wrong so I can get him to redo for free.
I had about an inch gap when they finished the job but now the front is like .5 inch gap and the back is tucked under the fender about an inch. Crazy rub.
What kind of drop do you have on yours?? I was thinking of 2 finger gap front & rear which is about 1.25 - 1.5 inch gap.
I had AMG C32 springs before and the back was rubbing whenever I drove over a bump. But the front was way too high.
I want this to be the last adjustment so I'm kind of worried about the rear rubbing if I drop it too low.
2002 C320 Wagon. Wheels: Carlsson 1/6 EVO 18" staggered.
'09 A4 S Line
IMO, the perfect drop is no gap in front and the tread (only) tucked in back. If you specified a certain ride height before install, the installer should adjust the height to your liking with no questions asked. If you didn't specify how low you wanted the car, that's another story.
2002 c320 wagon
That's about the drop I have right now about but the back is rubbing like crazy I can't even drive 10mph without hearing a loud screetch comin from the back.
I knew it was going to settle. But I thought only like .5 inch max. but the rear settled 2 inches.
The guy is giving me grief cause he has to take apart the rear to readjust the height. I already spent Saturday morning arguing with the guy for over an hour over this so it's just easier for me just to pay him $100 to redo it. When I went to pick up my car he showed it to me on the shop floor with 1 inch gap on front & rear and I said it was ok. 10 minutes after driving it I hear a loud rub from the back. Pulled over and I see that the tire is now tucked under the fender about an inch. & I can barely stick my finger (flat side) in the front gap.
He did suggest that I roll my fender & remove the fender liner to keep this drop but seems like more work.
'09 A4 S Line
2002 c320 wagon
Yeah maybe I'll do that.
But regarding the drop.
Front. Currently no rub except when wheel is turned all the way and even then it's not so bad.
Rear. Bad bad rub. But you are saying you have your tread tucked under the fender and you have no probs? Did you roll the fender? I feel like it's rubbing the fender and the plastic liner because there's 2 different rubbing noises. I had AMG C32 springs on there before and I was getting rub on bumps with 1.5 finger gap (about 1 inch).
I'm trying to decide how low to drop the rear and then how to balance the front.
Are you saying the front should have a larger gap than rear? I'm hoping I can do 1 inch in the rear and 1.5 inch in the front but I'm worried it's still going to rub.
'09 A4 S Line
2002 c320 wagon
I believe this is what I have but I'm at work so I can't check for sure. I'm unsure about rear tire size.
Rims: Carlsson 1/6 Evo 18x8 Front. 18x9 Rear
Tires: Kumho Ecsta Supra 235/40/18 Front. 265/35/18 Rear
'09 A4 S Line
That sounds about right, but need to know the wheel offsets too. The only thing I can figure is that maybe your rear offset is too low? Either way, some fender rolling and/or shaving should fix the problem.
2002 c320 wagon
BlakeP - Thanks for all your help bro.
OK I understand fender rolling but what's shaving? Is that for the plastic liner? And what kind of shops do this? Body or performance?
'09 A4 S Line
What I did was take my Dremel with the grinder tool and shave down all the areas of the fender that seemed to stick out further than the rolled part. The worst parts are at around 10 and 2 where the impact strips are. You should completely shave off the tab at the rear bumper impact strip and grind down the area behind the side impact strip. Make sure everything is smooth and won't cut your tires if they happen to make contact. If you aren't comfortable doing the work yourself, a competent tuner shop or body shop should be able to take care of it for a reasonable price.
2002 c320 wagon
BlakeP
I have another question. I think I'll try to roll the fender & shaving before raising it up. When you roll the fender does it pull out (increase width) or just fold the lip of fender?
As I understand it it will make the car slightly wider, correct? How fas out should I pull it.
Another question. What do you do if it's rubbing against the liner?
'09 A4 S Line
BlakeP
2002 c320 wagon
OK good to know.
I can confirm my wheel specs now:
Rims: 18x8 ET35 Front. 18x9 ET 35 Rear
Tires: 235/35/18 Front. 265/ 35/18 Rear
Gap in front: .25 inch Rubs only if turned all the way
Gap in back: .75 inch Tucked under. Lined up with where the treads start.
Does this sound like the right drop or too low?
The fenders already look bent in a U shape from the factory. Rub could be coming from the clip that holds bumper to fender but I can't tell for sure. I can see scrapes on the outer ridge of tires and that area looks like it's almost touching the tire.
I trying to decide if I should try rolling the rear fenders first ($80). But if that doesn't work I'll to raise it. (Plus additional $100)
Or just forego the rolling and just raise it? ($100)?
'09 A4 S Line
OK good to know.
'09 A4 S Line
Having said that, I have seen a couple of w203's over here on 20's absolutely slammed with about 1/4 the wheel tucked under, but they may have rolled the wheel arches and thin rubber???
Also just quick, the guy who installed my set up said it was a nightmare to adjust the rear, but the guy I'm using now does it in no time, no hasstle. I think he must have a tool for this as he does it so fast. Might not hurt to drop into another mechanic, the guy i found is one of those modded german car nuts, he knows the ins and outs of **** I didnt even know was built, nor did I care lol, but these guys always seem to know the tricks to doing these cars, imho
Phil
2002 c320 wagon
Phil,
Thanks for the input buddy. I decided to set the front at 1" gap both front & rear and also roll rear fender. I hope this takes care of all rubbing issues.
'09 A4 S Line
2002 c320 wagon
Just an update. I had the car raised a bit and I'm very happy with it. Looks balanced now so I think it was too slammed before.
There's now an inch gap in the front and the rear is about level with the fender edge. No rubbing except when hitting a bump. Haven't had any passengers yet so I'm crossing my fingers. I'm going to have some guy roll the fender this weekend and I'll just shave the tab myself. For some reason I couldn't get any shop to shave that tab off. No one wanted to be responsible.
'09 A4 S Line
