Which audio cables are these?
Old Jun 7, 2008 | 03:46 AM
Kobazz's Avatar
CL203 (2001)
Sorry for the blurred image
Can someone tell me which audio cables these are? Ok. nr.1 is the antenna plug. What are nr 2 and 3?. Could nr 2 be the microphone plug from the handsfree cradle? If not where can I find the microphone plug and are there adapter plugs to 2,5inch audio jack available outthere?
I wanna use the original interior integrated mic and not the mic that goes along with the 2-din kenwood system. Is that possible?
I also need to know the meaning of these car wires:
and
Old Jun 7, 2008 | 08:53 PM
bumpnzx3's Avatar
W203 C230SS
this is all i've got- not sure how much it helps
File Type: pdf
Old Jun 8, 2008 | 09:35 PM
e1000's Avatar
a quarter mile at a time
#3 is the optical cable
Old Jun 9, 2008 | 03:46 AM
Kobazz's Avatar
CL203 (2001)
@bumpnzx3, thanks man. You really helped me out with this one.
Old Jun 9, 2008 | 09:15 AM
Kobazz's Avatar
CL203 (2001)
Where does the mic lead to?
Could someone explain to me where the wire of this mic leads to?
I need to find an end of this microphone wire. Any ideas where to look for it?
Old Jun 9, 2008 | 10:27 AM
bumpnzx3's Avatar
W203 C230SS
no problem- i always save stuff like that when someone else posts it. never know- someone else (you) could need it down the road, or i could need it for some reason. i've got all sorts of little goodies like that saved on my computer
Old Jun 9, 2008 | 04:37 PM
JLD2k3's Avatar
2002 C320
much more helpful than "STFF"
Old Jun 9, 2008 | 05:29 PM
bumpnzx3's Avatar
W203 C230SS
i decided that wouldn't be a good idea since i couldn't find the thread that i copied that PDF from
Old Jun 9, 2008 | 09:20 PM
DiBenz's Avatar
19 XC90
Thumbs up
DIY vehicle wiring information. If you can't find what you are looking for in that application, you can call their support line and they will give you the information you need.
Old Jun 10, 2008 | 04:11 AM
Kobazz's Avatar
CL203 (2001)
Yeah, thanks again for the pdf.
To come back to my last question. I still cant find where the microphone wire leads to. Ideas anyone?
Old Jun 10, 2008 | 10:45 AM
-Shadow-'s Avatar
C220 cdi W203
1. is antenna
2. is phantom antenna (since when have the US models this antenna sucks because you need to buy an adapter for a good functioning of the antenna)
3. is optical (phone or CD-changer)
The wires of the mic go to the dome-light you can uncouple it there it just plugs in. Watch out for what you are doing don't mess up the cabling and cover the ends of the optical connector because you can damage it. When selling your car stock is always more interesting for buyers.
Old Jun 11, 2008 | 04:19 AM
Kobazz's Avatar
CL203 (2001)
Thanks shadow. I need the mic wire to come out somewhere near the audio console.
Old Nov 26, 2008 | 12:29 PM
jjsat's Avatar
C230 Coupe
Treo 600 installed in C230 Coupe
I have installed Treo600 with THbury cradle I plug set to lighter plug and is working Ok but one option left to wire is muting of my radio when phonre is calling. I have seen PDF and my guess is that I can run wire to A3 tel mute conector of may radio. Any body can help if this is Ok to do that. I do not want to burn the radio.
Regards
jj
Old Nov 26, 2008 | 02:34 PM
Glyn M Ruck's Avatar
Super Moderator
LOL you & me - I just dump it all in a file called Car and my filing sucks
Old Nov 29, 2008 | 12:52 PM
zeet's Avatar
The ISO connector with three wires (two brown, one blue) is the CAN-bus and D2B wakeup. The 1 and 2 are the two FM antennas for diversity.
Old Nov 29, 2008 | 01:11 PM
bumpnzx3's Avatar
W203 C230SS
sounds like our filing systems are more or less the same
Old Nov 29, 2008 | 01:21 PM
Moviela's Avatar
In US cars and my car in HK the Mic wires meet in a multipin connector that plugs into the premium audio amplifier on the right rear wheel arch. The Mic in my car is intended to adjust the volume of the audio system relative to the noise in the vehicle. In my car the music becomes louder when I drive with my wife.
Old Dec 1, 2008 | 12:42 PM
billbugger's Avatar
C230 Kompressor Sport Sedan
