voice control module
Old Jun 15, 2008 | 07:51 PM
yikes's Avatar
06 e350 17 glc300
hi
is it possible to add the vcm to a 2007 c-280? i notice a black plastic covering where the stalk should be.
if its possible does it need to be version coded to be activated?
are these units universal for all mercedes models or are they model specific?
the car has no nav and only the cd player with a cd changer in the glove box plus the xfm.
thanks
Old Jun 15, 2008 | 08:19 PM
benzmodz's Avatar
W203 slightly modified
Depends on your prew-wiring.
PREWIRED: Voice module, adjust microphone connection, adjust optical Version code. Add missing stalk on steering. Check relays and fuses.
NOT PREWIRED: Same as prewired + install new wiring harness and install optical.
Must have a phone kit pre-installed to make it economical. Otherwise need to add a mirror wiring harness for microphones and maybe also a mirror with microphones if no Teleaid is installed.
Old Jun 15, 2008 | 09:11 PM
yikes's Avatar
06 e350 17 glc300
well i didnt expect an answer from you...but i appreciated it..
thanks
Old Jun 16, 2008 | 08:15 PM
SteveAustin's Avatar
2005 C230 Kompressor Sport Sedan
Originally Posted by yikes
hi
thanks
Steve tried to do it on my 2005 c230, it wouldn't work and I have the OEM phone setup. It may work with a NAV unit, but I can safely say it won't work with Audio 20.
Old Jun 17, 2008 | 02:33 AM
yikes's Avatar
06 e350 17 glc300
i was toying with the idea of getting the mcsII put in last yr but steve never came to the east coast and the more time that passes by...the cost of it gets less and less worth doing. anyway i guess if i ever change my mind ill have steve throw in the vcm then....i trust steve as he did some work for me on my 2006 E-350...
thanks for the info
Old Jun 18, 2008 | 09:22 AM
tudu's Avatar
Mercedes Benz C200K Sport Edition and 04 C55 AMG
I had Comand installed last year, and yesterday had phone pre-wire, bluetooth HFP cradle (which i use with my iphone) and Lingautronic installed. What a fantastic bit of kit, and everything's working fine. Also had C55 steering wheel with paddle shift put on, but needs bit more star programming to get it to recognise gearbox selector module.
Old Jun 18, 2008 | 10:25 AM
BF_JC230's Avatar
2005 w203 C230
I wonder if it is a European thing and a lack of ability on the American MCSII system...as Lingautronic is something I would like in the future too....
Ahh dreaming...
Jake
Old Jun 18, 2008 | 07:18 PM
yikes's Avatar
06 e350 17 glc300
Ahh dreaming...
Jake
do you run an american mcsII?
Old Jun 18, 2008 | 07:36 PM
BF_JC230's Avatar
2005 w203 C230
Not yet...I have to fit that toy in my modding budget...
I want it...along with a bunch of other things...
Jake
Old Jun 18, 2008 | 08:32 PM
yikes's Avatar
06 e350 17 glc300
those that have done the mod to an mcsII...what did you guys do for a gps antenna and where did you put it? i heard inside the dash??
thanks
