I got my '03 C320, but with no C4 bi-xenons...
Old Dec 19, 2002 | 06:37 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Originally posted by intakex
i was wondering if you can change the settings of the us version to the eur settings?
No, you cannot. The projectorlens is different (the US version has a horizontal line, the euro versions don't have that line) and the part that makes the actual light pattern is a steel cover plate between the xenon reflector and projector lens and is completely different shaped. You have to change that plate inside the xenon projector to change the light pattern.
greetingz,
Old Dec 20, 2002 | 06:52 AM
Drew_ML's Avatar
'00 ML320 Elegance/'03 C320 4-matic
Originally posted by Class C
Also it appears that the US spec ones turns white and loses it's blue hue after the bulb fully heats, where as the Euro spec, retains it's blue hue. Jay
Uh no, it's the same Xenon bulb so there is absolutely no reason why there would be a difference between the Euro and US-DOT spec bulbs. HID bulbs need to break in though, so if you have a really new vehicle, they will appear rather yellowish for the first 50 hours or so.
