W203: Questions to Owners
I'm a South African and we regularly have very robust interaction followed by a good evening in the pub with no hard feelings. My American colleagues are frequently surprised by this. It's just our culture. We say it the way it is with no circumlocution and move on. There is nothing personal. - Of course some believe that we only open our mouths to change feet!!!!!!!!!!!!!!!
Kind Regards & please don't feel any discomfort.
btw - the new V6s are about 15% more fuel efficient than their predecessors which were LEVs in their own right.
All's good, and no problems...I didn't take any offense, but after re-reading my post, I did notice I was being biased towards the C230K. But it's nice that we're all able to discuss things, and the way I look at it, I've learned more about the engines and their efficiencies from everyone posting in this thread. Your comments on the durability of the C240 were great, and it goes to show how well they're built. Which has to be at least one of the reasons I see so many C240's in my area.
Cintoman
As for brakes, I live in a mountainous region and use them extremely hard. On the weekends when I drive for recreation, I find them overheating occasionally. I know that any car Mercedes makes will be able to emergency stop 10 times with no trouble. Even a non sport model is still a Mercedes after all!! But agressive driving on roads with steep inclines requires an extra bit of braking ability; this is a type of situation where I would prefer a C230 Sport.
Again, thanks for your comments. I was wondering where I might come across an E240.
OK - your brake gripe is high temperature fade - understood! Yes I think I would bolt on a set of Brembo's if I had that problem. Our line up in South Africa is different than yours - we don't have a Sport. We have Classic, Elegance & Avantgarde. Then you can order the, so called, Sport Pack fitted to any of them. Having the plant on our doorstep in East London makes it easy to configure cars the way customers want them. Are the drilled rotors & same sized badged calipers really much better? Here it's considered more of a cosmetic issue but not a serious upgrade. I've never made the comparison so I don't know but my motorsport experience tells me that you would need a more substantial brake upgrade to be really meaningful.
Sorry can't help you with an E240
See another forum member's car with CLS 500 wheels. Pity he does not have Bi-X headlights
Do you have any experience to share with good ceramic pads & how they might or might not contribute to rotor (disc) wear & noise?
I'm probably going to get a set of ceramics once my front pads go. Mostly for the brake dust issue and little better stopping power.
Here's the link to the review.
https://mbworld.org/forums/showthrea...hlight=ceramic
The auto manufacturers are still experimenting with brake formulas. BMW's seem to generate a lot of brake dust too. This is simply the price we pay for good stopping characteristics and fewer toxins in the air. Yes, I am annoyed by the dust, but I do not want to return to the old asbestos pads.
It's the reason I raise the ceramic issue. If ceramic pads were the panacea of all braking ills the OEMs would use them - Why don't they??? They obviously have some issue with them.
Most average people dont know when there rotors are going bad, so they just go off of when the car makes the low brake metal grinding noise and change both.l
Most people dont really know, so they change both. Its more revenue for the dealership.
if you have ceramics, most people are not going to know when they need to change there rotors.
i dont really think its cost. Mercedes can easily make it a $1k option and get away with it. Just most people dont really need it for everyday driving.
how many people actually take there c-class on the track or through twisty canyons? its probably less than 1% of the buying customer base.
To replace them, I'll be getting all new EBC rotors which are slotted and "blind drilled" (aka dimpled) for the front and rear, plus all new EBC Red Stuff pads (utilize ceramic materials). In the installation process I will flush the brake fluid and bleed the entire system at all four corners.
Funny enough though, the brake fade I experienced while on my favorite mountain loop was actually a fluid fade. My brake fluid was boiling and I didn't notice any significant loss of brake friction (kudos to rotors and pads) until the point that my brake pedal started to travel to the floor. My brake pedal still travels a little bit further than normal even now from this episode.
The section that overheated my brakes is an extremely long, curvy decent that overheats lesser cars brakes under normal driving. Let alone anything resembling spirited driving!
The real point of my post, and the answer to your question is "yes and no"
Yes I am going to get some ceramic pads and No, this is not going to keep my brakes from fading.
New fluid with less water contamination will help my fading problem. I am not sure, but I hope my car uses DOT5 spec.
I'm not 100% sure, but on these cars I think the Rotor is the ceramic part, and I bet the pads aren't even ceramic. This is like a $10,000 option on a Ferrari.
When I get my "ceramic" EBC pads, I will certainly not be telling anyone that I have ceramic brakes. Why? because I don't.
My rotors are grooved severely and very worn down, rotors are expensive and should not need to be replaced as often as they are.
I want some nice soft gentle pads that have an extremely high coef. of friction at all temps. I could care less about brake dust and pad life. I'd rather replace pads at 10,000 mile intervals than replace the rotors at 30,000. Plus I wash my car every week, so brake dust is okay by me.
Sorry for so many sequential posts, I had a lot to say in re: to this topic.
. Probably my fault.
About a 75% reduction in brake dust, and much longer lasting brake pad than OEM.
Carlos
Saprissa
