C230 Service B completed
Old Dec 19, 2002 | 08:00 PM
DCX Engineer's Avatar
My car was at the dealer for two days to get Service B and some warranty work. The dealer performed the filter/oil change, replaced dust filter, air filter and wiper blades. They also rotated the tires, checked the brake pads and rotors.
The warranty work I had completed was a drivers side door seal replacement and replacement of the panel/cargo cover for the hatch. The door seal was coming loose and not fitting properly. The panel/cargo cover had a broken plastic pin/hinge.
I drove their 2002 E320 4Matic loaner for two days. I'm glad to have my couple back.
I also learned that my salesman no longer works at the dealership. No loss. He knew little about cars.
Old Dec 19, 2002 | 08:08 PM
speedfrk's Avatar
C230 coupe 6sp
Did they replace all the filters and wiper blades for free? I just had service A done, but my wiper blades are totally shot, and I forgot to ask them about it. The passenger side is a special curved blade that you can't get from a regular parts store, and my dealer is 45min away. I wish I had remembered that. They wanted to rotate my tires but were going to charge me to do it, so I said no at 92.00/hr.
What didn't you like about the loaner?
Old Dec 19, 2002 | 10:55 PM
Wiper blade inserts and tire rotation are included under Service B. I would assume if the wipers were in poor condition at Service A they would be covered. Although, I also assumed tire rotation with the C7 17" Z-Rated tires would be covered at Service A (12,500 miles), but they would not budge on the $20 charge.
Old Dec 20, 2002 | 07:18 AM
avlis's Avatar
2008 VW GTI
I noticed that the pass. balde is curved. I don't think that is stopping us from using a regular insert (just the rubber, not the whole blade) from a parts store though. Anyone know for sure?
Old Dec 20, 2002 | 10:16 AM
TXTiger's Avatar
2002 C240 6 spd manual
I just had Service A performed on my C240 (10,500 miles), and my service advisor threw in tire rotation for free......
I would think replacing the wiper blade insert just requires you to get a long enough insert......it will flex to conform to the curve of the blade....
Old Dec 20, 2002 | 11:11 AM
speedfrk's Avatar
C230 coupe 6sp
"I would think replacing the wiper blade insert just requires you to get a long enough insert......it will flex to conform to the curve of the blade...."
No, actually the blade is molded in a curve, and if you put a standard blade in, it chatters real bad.
Old Dec 20, 2002 | 12:20 PM
avlis's Avatar
2008 VW GTI
Well, my factory blade chattered like mad. The stealer replaced it and it no longer chatters.
I disagree with you. As far as I know, the blade rubber is extruded in long lengths and then trimmed to various sizes. It's hard to believe that MB would create and entirely new mfg. process to mold curved rubbers piece by piece, and just to achieve a huge radius. I think a standard insert will work and not chatter as long as it's of a good quality compound.
Old Dec 20, 2002 | 12:33 PM
speedfrk's Avatar
C230 coupe 6sp
Take the refill out of the factory wiper blade assm, and you will see what I mean. It is definately curved, and not replaceable with a standard refill.
Old Dec 20, 2002 | 12:40 PM
TXTiger's Avatar
What's the MBUSA policy or the policy most dealers seem to adopt if you request to have them replaced prior to Service B?
Old Dec 20, 2002 | 01:16 PM
Matt230K's Avatar
2010 C300 4matic
It may not be replaceable with a standard refill, but it does not come curved. It might get that way after being in there for a while. I had mine replaced last week by the dealer and they were both straight. But they are soft rubber with a metal strip to allow them to bend with the wiper assembly. The aftermarkets are usually plastic on the top that can't bend, so this might not work.
Old Dec 20, 2002 | 01:22 PM
speedfrk's Avatar
C230 coupe 6sp
Maybe the new ones are not curved, but the factory ones are. I've had mine off 3 times trying to find blades locally, and all the auto parts stores look at it like it is off the space shuttle, and say "we ain't got nothin like that". BTW, it is only the pass side that is curved.
Old Dec 20, 2002 | 01:27 PM
Matt230K's Avatar
2010 C300 4matic
You sure it doesn't develop a curve by being on the car for a while? Those metal bars might bend when you put it in and then hold the curve. Cuz I know there wasn't a specific left and right blade that got put in. I hope they're the same length.
Old Dec 20, 2002 | 01:47 PM
speedfrk's Avatar
C230 coupe 6sp
On the coupe, they are not the same length. One is 22in the other is 24. And no, the actual metal part that the blade is molded or attached to is curved.
Old Dec 29, 2002 | 06:19 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Tire rotation.
Yeh, you'd think they'd rotate 'em.
The tire warranty specifies that they should be done every 10K
to maintain the tire warranty.
But the c7's don't last so long.
My service advisor said he saw no need to rotate them, they
were gonna wear out soon.
So next question is what tires to buy?
Costco has Bridgestone for about 600 a set.
I'm not spending 1250 on Michelins!
Old Dec 29, 2002 | 11:56 AM
Matt230K's Avatar
2010 C300 4matic
Re: Tire rotation.
What kind of Bridgestones? If they're S-03's, you could go with those. Kumho's are one of the cheapest. The new Yokohama AVS ES100 is also a fairly cheap tire and it is very good.
Old Dec 29, 2002 | 02:22 PM
Lynn's Avatar
Re: Tire rotation.
Where do you shop? Tirerack has the Pilot Sports for $169.
Old Dec 29, 2002 | 05:26 PM
Iceman's C230's Avatar
09' BMW M3 E90
Why was my Service A due at 8000Km and service B at 16000Km?
I am reading some posts here and some of you guy's are taking your 230 in at 10000 miles for service A? How is that? My computer said Service A due at 8000KM thats like what 5000miles? and service B was 16000km. Why did i had to get my car serviced this early compared with some of you guy's?
Old Dec 29, 2002 | 05:27 PM
09' BMW M3 E90
hoops wrong thread. Sorry..
Old Dec 29, 2002 | 07:56 PM
GTIDAN's Avatar
2002 C230K, Auto, etc.
Service A
Iceman
Your car has what's called a FSS (flexible service schedule) The electronics check your oil and decides when it needs to be changed. It's based on your driving habits, weather, rpm and who knows what else. Some folks on the forum have gone well over 10K miles before the computer told them to go in for service.
Does not mean there is anything wrong with your car.
Enjoy the ride...............
Old Jan 3, 2003 | 07:21 AM
That quote was from Wheel Works....
Old Jan 3, 2003 | 12:23 PM
GTIDAN's Avatar
Quote?
What quote?????
