SRS warning light
My srs warning light came on the other day. I accidentally left my key in the ignition while I unplugged the instrument cluster, would that throw an error? I check all the connections under the seat and all the fuses. Any ideas before I head to the stealer tomorrow?
key was in the ignition and I unplugged one of the control modules under the seat....
my srs light has been on ever since....
i read on here the only was to get it turned of is to go to the stealership..
-charles
You may not need to use Star Diag (though it helps)
Some handheld afternarket units will do it.
I'm trying to determine which ones as I swapped my
steering wheel and my iCarsoft won't clear it
and nobody within 100 miles that could do it.
So if you find one that does, let us know,
