View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#4551
'09 A4 S Line
+1
nothing is more of a headache than a pair of wheels that dont fit/rub your fenders, dont ever make that mistake. read the forums, tons of us here have been through diff sets of wheels and know what works and what doesnt.
FYI spacers will further push your wheels out toward your fender.
Basic wheel knowledge for Sport brake equipped cars:
Front offset: 28-35, 35 is pushing it close, may work depending on spoke design of wheels
Rear offset: 35
if you run coilover suspension say hello to 28-32 offset in front, because anything higher will rub the inside of the tires on the coilover.
this is basic offsets for aftermarket 19x8.5/9.5 wheels. its really simple once you know how things work.
Rear offset: 35
#4552
06 c230 v6 SS
Based on the information you give above, his wheels should fit. You forgot to mention one VERY critical step in determining fitment... lip size. 1.5" wheel lip up front is about the maximum for W203's with BBK, while 2.5" rear lip is very common and 3" is the maximum I've seen.
your right blake, anything over 1.5 is asking for drama.
jus remember if theyre cheap, and you havent seen anyone mount these wheels, there must be a reason!
#4554
06 c230 v6 SS
hmm, weird. thats so tricky!
but yea i jus looked at the pics and saw that et32, but jus looking at the lips i would figure they wouldnt fit, too deep, must be dreaming!
#4555
et32- as were mine. i am curious why Monet would have changed a proven Moven design. By changing the curve of the spokes- they didn't change the appearance of the wheel, they just reduced brake clearance. *in reference to my wheel mishap several months ago- not Chadski and the ebay wheels*
#4556
MBworld Guru
white and whiter
#4557
interesting- that's not what the seller (charles @ wheelautohaus) and Monet told me when I was trying to sort out what exactly was going on- since I knew the Moven version would fit.
#4559
More like post-sale B.S.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I heard that story after I ordered the Moven from Charles- and ended up with Monet- and found it didn't fit for *****. Charles claimed it was no fault of his- he even offered to send me a copy of the order he sent it for my wheels.
Ahh well- I don't want to think about it any more. I'll get all pissed off about it again. No big deal- that was 4 months ago. I like my wheels I have now a lot more. Had that never happened- I never would have saved a little more money and bought the wheels I ended up getting. Everything happens for a reason I guess
#4560
MBworld Guru
white and whiter
Ahh well- I don't want to think about it any more. I'll get all pissed off about it again. No big deal- that was 4 months ago. I like my wheels I have now a lot more. Had that never happened- I never would have saved a little more money and bought the wheels I ended up getting. Everything happens for a reason I guess![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
#4561
nope- not the MRR. you'll see in a couple weeks
i guess i shouldn't say, wheels i have, but wheels i ordered. i've had them on order since the end november/beginning of december. i do believe i will be the first on the boards to have this wheel. it's actually something i haven't read to much about. but, from what i can see (in person) and read- it's a pretty good quality wheel. it's no HRE or something of the sort, but it's not MRR either- something in the middle
#4562
2006 C350 SS
i found a couple pictures from when i tried to fit my moven's up. it really sucks- because i thought they looked fantastic from the side. depending on your wheel, you might be able to run a tire that isn't as wide up front to make it appear slightly better![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
19x8.5 et32 front with a 235/35 General tire mounted- 10mm spacer
So based off those photos and info...I understand that 1.5" lip on the Front is as large as we've seen...but without lowering right away...and rockin this wheel set-up I've got myself into....I CAN bust the 10MM spacer in Front and maybe squeez it by? And 5MM in Rear to keep it legit?
How big was the Lip on those Moven or whatever they were rims???
I really wana try and just get them on...8 MM I'm guessing just fully won't cut it?
Also, where is the best place/source to get these spacers? And FORSRUE Hubecentric?
I'm like depressed with this whole sh*t situation I got myself into...I'm so good at jumping the gun and indulging on things I reallyyy shouldnt...man this sucks...I'll be getting new wheels AGAIN this year...but I really would like to do my best to get this set-up going for a little bit..
Anyone know any European Car places that could give me a hand in Southern Orange County...Dana Point...Laguna???
Thanks again for everyone's time and help...I know this is annoying and in yer heads it's like "fu*k...this guy just needs to get over it"....cant help it though...I'm to stubborn or somethin...
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
THANK YOU THANK YOU THANK YOU to anyone with help
-Chad
#4563
2006 C350 SS
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
i agree with Frank- an et32 F with a 10mm spacer will push the tire (235/35) out past the fender by around 1/4". i ran into your same problem a while back- except i didn't buy ebay specials. i ordered a set of Moven wheels- only to find out when they came in (with tires mounted) that Moven had been bought my Monet- and they had slightly changed the design of the spoke. it wouldn't clear my calipers. long story short- i was stuck with them, sold them for a fairly large loss to someone here that didn't have big brakes.
i've also got a set of 5mm spacers (i think you said you just needed a small one for the rear) that you are welcome to, for the cost of shipping.
On top of everything else....is there any other tire option (other than the 235/35/19) in Front that would give any type of advantage or make this horrible mess ANY cleaner??? Sorry if that's just a flat out dumb question...I'm just going for anything at this point...
#4564
MBworld Guru
white and whiter
Thanks again for everyone's time and help...I know this is annoying and in yer heads it's like "fu*k...this guy just needs to get over it"....cant help it though...I'm to stubborn or somethin...![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
-Chad
-Chad
#4565
i can't remember what the lip was on those fronts i had- 1.75 or so![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
i still don't think i would risk it on your car- spacer or not. your bound to jack up a perfectly good fender on a large bump. besides- since you claim to be getting new wheels later in the year, why not just sell these and save the cash towards your next set. you could surely sell them for more now than if you actually use them for a bit, then sell them.
at this point, if i were you, i would just cut my losses, call it a lesson learned, and save for the next set of wheels.
#4566
2006 C350 SS
Albert
take the wheel to TWS www.thewheelsupply.com and ask for Albert. show him the wheel and see what he says. If you come tomorrow you may see me and mig there.
I would love to see yer ride and chat about it...thanks for the help buddy and I'm hopin to get these wheels goinnnnn!!!
#4567
'09 A4 S Line
#4568
01' C32o
Frank....I'm actually on the phone with Albert right now. He was a GREAT help. We're gonna try the 8MM and 10MM generic spacers before I go ahead with purchasing anything for good. That was awesome man and he thinks we can make it work so I'm going to head up there this weekend....you said you'll be there this weekend to???
#4571
Former Vendor of MBWorld
6-series bmw
New Line Of Performance Wheels
MBWorld Community,
Please allow me to introduce our new line of 3-piece forged wheels. We specialize in aggressive fitments & finishes for all performance applications. We currently have 2 designs and 2 more to be released early March. Check out the images below, we are extending a discount to all MBWorld members interested in our wheels.
![W203/CL203 Aftermarket Wheel Thread - All you want to know-modular01.jpg](https://mbworld.org/forums/attachments/c-class-w203/385228d1542322406t-w203-cl203-aftermarket-wheel-thread-all-you-want-know-modular01.jpg)
![W203/CL203 Aftermarket Wheel Thread - All you want to know-modular02.jpg](https://mbworld.org/forums/attachments/c-class-w203/385229d1542322406t-w203-cl203-aftermarket-wheel-thread-all-you-want-know-modular02.jpg)
#4574
Chroming my stock wheels
Believe me when I say, I have looked at practically every picture of all of your cars and wheels and they are all spectacular. I have also gone onto all of the wheel vendor related websites and shopped around. I just can't afford even the lowest priced rims for my car so I've decided to chrome them - well actually do a chrome exchange this Saturday. I think I got a VERY good price, but I'm wondering if they are going to look "cheesy".
Let me know what ya'll think....
Thnx!
Thnx!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#4575
Me personally- yes, I think it will be chee-z. However, that's just my opinion. I'm just not a fan of chrome- stock wheel or not. There is a guy with a red W203 that has chromed originals (17" funnel spokes).
Keep in mind- opinions are like buttholes; everyone's got one and they all stink![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I say leave it stock and save your cash until you can get some wheels. Besides- I would be willing to bet you could get a nice used set of wheels for the same price/less than you are going to pay for this chrome job. If the chrome job is really cheap- there's a reason. It's going to chip off or something of the sort. Also take into account- you are going to have to break your wheels/tires down, shipping, and then remount/balance your tires back on your other rims.
