View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#3301
265/30/19 is the biggest you can go without a fender roll. that is what i was running, but i went to a 19x10.5 wheel so i had to have the fender walls rolled to fit my 275 rear. No rubbing at all. Unless there are peeps in the back, which never happens.
#3305
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Wow...that's crazy 10.5 wheel with 275's (I'm assuming 30 series). That's actually much closer in circumference to 235/35R19 than 265's...hmmm, maybe I'll see if it works on my next set of tires.
#3306
'09 A4 S Line
Don't even think about it. You're lower and hardly have clearance now! I won't even go wider than 255's.
#3308
My car is lowered, and i dont have much rub at all, i mean i may get a skin here and there on a heavy bump, but on normal driving which is all the time cuz im running 25's you really dont have a problem.
Michelin PilotSport2, - 235/35-19 (f), 275/25-19(r)
#3312
Man i feel everything the road has to offer. Luckly its a Merc, and the ride is decent. I mean its no caddy, but its not as bad as if it were on a honda. But yeah i will go thru my cam and find some pics of the rims before the change.
#3313
Anyone need a pair x2 Nitto 275/30 tires? from 1-10 scale its 8 or above, great conditon .... wont need them so ill give um away for cheap.
#3316
Your speedo rating is probably faster than the actual speed you're travelling at.
#3317
See i understand the part that rlee said:
"if offset is lower, wheel is close to fender"
with the 32 offset being closer to the fender than a 35 offset 255/30 is prob. th best fit ?
Is this what your telling me?
#3318
#3319
#3320
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#3321
lol yeah i think you may be right about that, but i had them put it on the rack at the local merc shop, and they said it should only affect my mph by 2, or 3. Its my gas that is outta control. But yeah cost to be the boss i guess. I just like the way it looks. So i guess i can complain about it later. BUT also have some news, the car may be leaving tomorrow if i can work out this deal on an STI. So i may be saying bye bye to the w203.
Well see what happens![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
And you're right, the 275's look crazy on there. I'm sure it doesn't hurt on the turns either.
#3322
2006 C230SS & 2009 E350
#3323
'09 A4 S Line
Hyper Silver
1) Blake P (confirmed)
2) mj50 (confirmed)
3) emrliquidlife (confirmed)
4) splinter (confirmed)
5) rdscklasse (confirmed)
6) edtv82 (confirmed)
7) PheelinIt (confirmed)
Hyper Black
1) mzcloud (confirmed)
2) Eurowow (confirmed)
3) JonB C240 (confirmed)
4) AndySays (confirmed)
5) tozfeekum (confirmed)
6) mono (confirmed)
7) C24owner (confirmed - 8.5" all around)
8) toughguy (confirmed)
9) Stormin (confirmed)
10) Takso (confirmed)
11) Takso (confirmed)
Hyper Maybe
1) coin (FS: LM6s)
2) c230ftw (Need money)
The good news is, I have more pictures. The bad news is, our test set is still in production.
![W203/CL203 Aftermarket Wheel Thread - All you want to know-v715_hs-st_1.jpg](https://mbworld.org/forums/attachments/c-class-w203/385603d1542322463t-w203-cl203-aftermarket-wheel-thread-all-you-want-know-v715_hs-st_1.jpg)
![](https://i2.photobucket.com/albums/y30/gideonval/VMR/V715_HS-ST_2.jpg)
![W203/CL203 Aftermarket Wheel Thread - All you want to know-v715_hs-st_3.jpg](https://mbworld.org/forums/attachments/c-class-w203/385604d1542322463t-w203-cl203-aftermarket-wheel-thread-all-you-want-know-v715_hs-st_3.jpg)
2) mj50 (confirmed)
Hyper Black
6) mono (confirmed)
Hyper Maybe
1) coin (FS: LM6s)
![W203/CL203 Aftermarket Wheel Thread - All you want to know-v715_hs-st_4.jpg](https://mbworld.org/forums/attachments/c-class-w203/385605d1542322463t-w203-cl203-aftermarket-wheel-thread-all-you-want-know-v715_hs-st_4.jpg)
