View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Feb 23, 2011 | 07:22 AM
  #6776
C350_Coupe's Avatar
C350 Coupe (CL203)
I honestly don't know, sorry, hopefully someone will come along soon that does know
Old Feb 23, 2011 | 09:51 AM
  #6777
phister's Avatar
06 C230 SS 6spd
Originally Posted by dayum_8o8
I own a 2003 w203k sedan and currently lowered to the max on H % R coilovers
i recently purchased work varianza d3s rims...fronts are 19x8.5 +35 (225/35/19) and rears 19x9.5 +35 (235/35/19) and was told to order 20mm hubcentric spacers to clear the coilovers...is this true or will i need a bigger/smaller spacer...i am going for that vip flushed look and will rolll fenders if have to..thanks...
you'll be fine... the only c/o you need to worry about is KW cause the strut are bulkier and you'll need spacers cause it might rub. But if you want that the flush look I'd recommend getting 10mm spacers all around. I have +20 infront and +25mm in the rear. I had +20mm in the rear but the wheel was right on my fender and I didnt feel like pulling it anymore. You probably have negative camber in the rear since your dropped so low unless you have a camber kit. But once you put a camber kit on and adjust it your rears will be flush.
I'm in the process of selling my Tein's and getting H&R c/o. hopefully someone buys them soon.
Old Feb 24, 2011 | 04:52 AM
  #6778
dayum_8o8's Avatar
w203
shoots thanks man...i test fitted a 19x8.0 with the same offset and it barely cleared and may have rubbed when we tried on a 10mm...so were gonna try a 20 mm all around n just roll the fenders more if needed..i noticed that my stock rims were already rubbing the c/o..so i was a bit concerned with the works..ill keep u guys updated
btw..nice benz bro..whered u get the yakima roof rack?
Old Feb 24, 2011 | 04:55 AM
  #6779
dayum_8o8's Avatar
w203
btw..u using h & r hubcentric spacers?
Old Feb 24, 2011 | 08:55 AM
  #6780
phister's Avatar
06 C230 SS 6spd
no some other guys spacers... good quality though, haven't had a problem with them so far. If you going to do +20 in the rear you'll be needing to do more than fender rolling, be prepared to do some pulling. I pulled my rears quite a bit and the +20 still hit fender. It might work if you get really stretched tires in the rear like 225/35
Old Feb 24, 2011 | 01:54 PM
  #6781
dayum_8o8's Avatar
w203
i got 225/35 for the fronts and 235/35 for the rears...i was looking at the prices on allsprings.com and dayum theres a big difference in price for the 15mm and 20mm....if anything..i just might get the 15mm and pray that its the right fit..from most of the guys on the forums..
Old Feb 24, 2011 | 04:21 PM
  #6782
Glyn M Ruck's Avatar
Super Moderator
Strongly suggest you don't stretch tyres. It's dangerous as it operates the tyre sidewall way out of the design parameters.
Old Feb 26, 2011 | 10:00 PM
  #6783
dayum_8o8's Avatar
w203
okay..just ordered h & r 15mm for the front and 10mm for the rears..should be good enough..
phister..where did u order your roof rack and rear spoiler..ebay??
Old Feb 27, 2011 | 12:25 AM
  #6784
phister's Avatar
06 C230 SS 6spd
Got roof rack at Sun Ski & Sports, they had a sale when I got it. CF lip, spoiler and roof spoiler I got from Gary Suveener a sponser on here.
Just make sure you buy longer bolts to accommidate the spacers. RADUSA will probably have them.
Old Mar 1, 2011 | 04:03 AM
  #6785
dayum_8o8's Avatar
w203
Shoots..the roof spoiler will prolly be my next investment..
Btw..do u know what size bolts I need to fit the rims with the spacers?? I heard if I get too long of a bolt for the rears it may damage my brake assembly..n F**k that!! I don't wanna buy the wrong size bolt n mess up my brakes...
Old Mar 1, 2011 | 08:05 AM
  #6786
Super Moderator
Measure your standard bolt & add the thickness of the spacer. Then you can't go wrong.
Old Mar 1, 2011 | 08:58 AM
  #6787
phister's Avatar
06 C230 SS 6spd
I believe our stock lug bolt is 39.9mm shank... you'll want to get 17 hex, 45mm shank, acorn seat (since you have Work wheels)
Old Mar 1, 2011 | 08:27 PM
  #6788
dayum_8o8's Avatar
w203
45mm shank..if the original is 39mm it wouldnt be a 54mm for the front and a 49mm in the back? If I were to add in the mm of the spacers..
Old Mar 2, 2011 | 12:30 AM
  #6789
phister's Avatar
06 C230 SS 6spd
Yea my bad I didnt read you got 15mm and 10mm in the back... you'll have to get 55mm and 50mm lug bolts. They round it up.
Old Mar 2, 2011 | 06:21 PM
  #6790
amanonfire's Avatar
W203
I'm looking at these wheels and was wondering if MBW has a sponsor that sells them, or if there are other brands with similar looks for about the same price ($1000/set).
I'm looking for 19" staggered 8.5/9.5, already have tires.
TSW Nurburgring
VMR 710
Old Mar 7, 2011 | 04:12 AM
  #6791
BABYBENZZZ's Avatar
BENZ w203
w203 rim help
hey guys i found a nice set of:
MIRO STP3's for my benzo
19x8.5 et 32
19x9.5 et 40
now i wanna know is this all gonna work ... before i pay!
Old Mar 7, 2011 | 04:50 AM
  #6792
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
yes
Old Mar 7, 2011 | 04:49 PM
  #6793
BABYBENZZZ's Avatar
BENZ w203
eh
ive had rim shops tell me im crazy :S
Old Mar 7, 2011 | 04:55 PM
  #6794
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
Offsets should work, but 19's up front are a very tight fit and will diminish the ride quality. You could also experience fender rubbing depending on your tire size.
Old Mar 7, 2011 | 09:56 PM
  #6795
glocati's Avatar
2016 GLE 350
Depending on what brake calipers you have up front, the fronts will or will not clear. You don't specify in your sig if you are a sport equiped car or not. Sports have bigger front calipers. You may clear with a 32ET depending on rim design/backspacing.
The rears will be a bit tight inward as well. 35mm would be better.
Check out the "stickies" on the front page. There's a million page thread on wheels/offsets.
Good Luck on your wheel search
Old Mar 8, 2011 | 02:00 AM
  #6796
BABYBENZZZ's Avatar
BENZ w203
i found a nice set of bbs lm's 19x8.5 et45
what should i do for spacers, i took the brembos off for the winter
Old Mar 8, 2011 | 02:13 AM
  #6797
phister's Avatar
06 C230 SS 6spd
I'd run 15mm spacers or 20mm spacers all around
Old Mar 8, 2011 | 12:04 PM
  #6798
BABYBENZZZ's Avatar
BENZ w203
lol
phister u really think 19x8.5 et45 with a 20mm spacer front and back...
Old Mar 8, 2011 | 05:13 PM
  #6799
phister's Avatar
06 C230 SS 6spd
why not roland has 20mm spacers... long as you have the correct lug bolt length nothing will happen.
Old Mar 9, 2011 | 11:59 AM
  #6800
BABYBENZZZ's Avatar
BENZ w203
lol
whos roland. phister mbworlds ur next gf lol
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
