View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#7526
06 C230 SS 6spd
Hey guys, i am looking for some advice to see if these will fit ok.
My car is 2003 mercedes c class sports coupe (CL203), the car currently has the stock 'electra' wheels, 205/55/16 tyres & from what i have looked up the offset is ET37 16x7J.
I have bought some 18" alloys to put on, 225/40/18 tyres, offset is ET37 18x8JJ.
I would like to wheels to sit flush with the fenders, what spacers, bolts etc would i require?
Any advice is greatly appreciated.
#7527
CL203 Coupe
#7528
06 C230 SS 6spd
You'll have to measure. Take your stock lug bolt and measure its length, the threaded shaft part, then put it in the stock wheel and measure how much sticks out the back side. Then use the same lug and place it in the new wheel and see how much it sticks out. Then subtract or add how much you need for it to stick out the same amount as it does on the OEM wheel. That'll give you the basic length of the lug you need. Then add the length of the size spacer you'll get to the total of the new lug length and that'll give you the final length you need with the spacer. Measure in mm
#7529
#7530
Hi, I have a question for the expert wheel...people.
I remember when my mom got my c240 from CarMax back in 2004, and it had these rims on it(or something extremely similar to it) but the finish was chrome.
What I was wondering is if those ever were a stock "option" for an '02 c240, or if they came from another Mercedes...or what.
They were replaced in 2007 because she hit a pot hole and ruined both of the right side rims and tires(from what I remember those 5 1/2 years ago, 1 of the rims was completely flat for a good 4 inches, and the other had a crack shot down to the lug.
![](http://www.carshine.com.au/Wheels/Wheels%20-%20AMG%20W210-202%20Style2%2017-18in.jpg)
#7531
06 C230 SS 6spd
those are the AMG/OZ Aeros, they are not an option for our cars. They came on models like the older SLs if I remember right. they came in different styles, I had the Aeros two which was a 3 piece design. The bad thing with Aeros were that they were know to crack at the mounting lug point.
Did hers look like these
![](http://www.benzworld.org/forums/attachments/w126-s-se-sec-sel-sd/204924d1226805285-nice-set-16-inch-amg-aeros-wheels_amg1.jpg)
#7532
Trying to bring back my interest in this car again.
I was told before.. It's not beneficial to drive on aftermarket 17" wheels huh
Found the old set i was looking at before, 17x8 et 45 front 17x9 et 42 rear bbs lm with fresh tires for $1200.
Can't go wrong right? Would it work? I always wanted some LMs during my w203 life :p
#7533
06 C230 SS 6spd
#7534
Gotta love that flush look! Personally I'm a bit worried that it might look weird since it's small.
What would I need to do for these CCWs
18x9.5+22 (3.5" Lip with Low Disk Face) with 225/40/18 Nankang NSII
18x8.5+22 (2.5" Lip with Mid Disk Face) with 205/40/18 Nankang NSI
![](http://i419.photobucket.com/albums/pp272/choleaoum/D95CBF76-7143-4DCE-B752-879BEA6EAC3F-27109-000008B39E6BDC5D.jpg)
I thought it would go well with blue/silver + mercedes blueish tint windows.
Would I have to roll the fenders a lot?
#7535
Moderator Alumni
You can use: http://www.1010tires.com/WheelOffsetCalculator.asp
Some quick assumptions:
Rear:
w203s run 9.5 et 35 and 255 w/o an issue.
Front:
springs/struts: w203s run 8.5 et 35 w/ 225/235
coilovers: w203s run 8.5 et 27-28 w/ 225/235
Looking at those ccws and tires, I think they would work w/ some camber in the rear. You might need a spacer up front to clear brakes, but with the 205/40s up front, you'll have plenty of space to space out if needed.
Rear:
Front:
#7537
Thanks for the info. I was always curious after never seeing those on a w203.
#7538
Rear:
Front:
Rear:
Front:
It's just that I don't have enough spacers to play around with. Was hoping to buy what I need to get a flushed stance.
But I'm sure that's not possible, going to be trial and error. Hopefully the front doesn't require spacers bigger than 10mm!
#7539
Thanks for the replies guys.
You don't need to trial and error, use the offset calculator and measure with a ruler when you get your wheels.
#7540
06 C230 SS 6spd
Ok guys heres the issue with CCWs on post facelifted models with the larger calipers. No matter the offset you'll need spacers, point blank. the offset calculator isnt going to help in this matter no matter how low the offest. With 3 piece wheels the wheels are constructed using the face (which is usually built the same way, no concave and such). The offset is built by the inner and outter barrel sizes. Thats why on my cars that are pictured with CCWs usually give you the lip size not the offset.
With that said since CCWs faces dont have a lot of backspace like other wheels, you'll need at least a 8-10mm spacer for it to clear the caliper. I know this personally. I ordered 18x9 +25 and 18x10+20 and the front still didnt clear. so I have a 10mm in front and to give it an even look in back i put a 5mm in back. so I'm running at +15 all around. Plus you'll have to do quite a bit a of fender rolling, pulling, and grinding. Since they are 1/2" shorter in length then mine you'll probably not have to do as much as I did, but you'll need a camber kit in rear for sure because you'll have to do a little bit of negative to get it tuck under the fender without rubbing anything especially the bumper tabs. But that depends if you're going to lower the car too. If not then with the stretched tires you'll be fine riding at stock height with maybe just rolling the fender.
The main issue with lowering on low offset and wider wheels and tires on our cars is the bumper tabs eating at the wheels. Tru and I have had to grind down our bumper tabs for the rear bumper and then the impact tab by the rear doors.
#7541
2005 C230K
Continuing with this theme:
Brand: Sport Edition (ASA)
Model: ST4 - staggered 19x8.5 / 19x9.5
Color: Silver w/ polished lip
Tires: Continental ExtremeContact DWS 235/35 and 265/30
Offsets: 32 front, 36 rear
Suspension: OEM Sport
![](http://www.charlotteseo.net/images/SANY1557.JPG)
Please disregard the temporary lack of center caps...
#7546
You guys think 17x10 offset 15 is impossible for the rears?
It's with a 17.8.5 offset 20 for fronts.
I just want to think about that setup because its a 3" step lip for fronts and 4" for rear. But I might just go 18x8 et 35 and 18x9 et 40
I think I have a misunderstanding of how offsets work. Even though we say 25 20 is probably the lowest offset we can go. We would still need to add spacers and adding +10 + makes it into +10 or +15 offset.
#7550
I've been sitting on my bald stocks for awhile. I found a deal on craigslist with new bbs lm reps on brand new hankook ventus v4 215/35/18 (or 215/40/18) for $600. I just decided to jump on it.
The tires alone are like $100ish a pop. So I thought i'd decided to buy it while I look for some authentic wheels.
All these bbs lm reps on this thread were 18x8.5 et 35 18x9.5 et 40 or 19x8.5 et 35 19x9.5 et 40. For these specs we should use 10mm in the front and 15mm in the rear so it'll be flush with no rub.
With my specs, 18x8 et 35 and 18x9 et 40. Should I still go with the 10mm up front and 15mm in the rear? Or since it's .5 less, I can do 5mm front and 10mm rear?
I'm planning to finally dump my h&r coilovers in the front to the lowest.
