View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#7276
Need help with spacer fitment. I have a 02 C230 Coupe with 18X8 35 offset on the front and rear. I would like to purchase some spacer for the rear wheel. I cannot decide between 10mm or 15mm. The tire size is 225/40/18. Thanks!
#7278
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
If you want a set of 10mm, I have two sets of the Eibach pro spacer, one used and one brand new. PM me for pricing.
#7279
06 c230 v6 SS
So will those esm bbs rs reps work? anyone test fit to see how much clearance is needed for the front brakes?
at et 35 front, will a 5-8mm spacer clear the brake?
at e40 rear wont a 5 mm spacer do just fine?
if these could clear running 225/255 setup, i might sell my polished monoblock reps for these...
i think my reps were custom made for et 28 front and 30 rear, and they fit great, no rubs.
#7280
2005 Mercedes C230
#7281
06 c230 v6 SS
Yup they work, I have that setup. Front you're going to need a 12mm spacer to clear the brakes and make sure to get H&R front spacers specifically for our cars, rear you can get any brand. Rear you should be good with a 12 mm spacer aswell. Definitely get 225 series tire for the front to avoid rubbing if you plan on lowering and 255 or 245 in the rear should avoid any rubbing issues. You are going to have a problem with fitting front center caps with the H&R spacers though, the hub extension on these spacers doesnt allow the center caps to clip onto the wheels, what I did was cut the little clips on the centercaps and used some clear silicone to attach them to the wheels. Oh well halfass way of doing it but it works.
#7282
2005 Mercedes C230
LM style, I just posted a couple of pics in the picture thread
https://mbworld.org/forums/c-class-w...hread-228.html
#7284
Hey I'm new to the site and am also a new mercedes owner. I've been wanting to get a set of wheels for the 2004 C320 4matic i just purchased but want to make sure i get ones that will fit correctly without any adjustments. The wheels i have been looking to buy are 18x8.5/35 offset/66.6 bore/5x112 bolt pattern. Would these fit on my car.
#7285
06 C230 SS 6spd
If you don't plan on lowering or rolling and pulling the fender then you should look for an offset between +25-38. As for tires you shouldn't exceed 235 infront and 265 rear, 275 can fit but you'll need to get the right offset so nothing rubs.
#7286
Are +25 in the front and +20 in the rear considered flush offsets?
Wheels are Authentic BBS LM 17x8. +45 front and +42 rear. The owner don't really know much of the wheels.What spacers should I run to get a flush fitment? It'd be nice to be a little tuck in so I can dumped it all the way.
#7290
Mercedes Benz 230 Kompressor Sport
C230 rims spacer
WeHi, I'm Interested in obtain spacers for my car but I'm not sure the right ones for my actual setting. My Mercedes c230 kompressor sedan 2005 runs with 19-8.5 front (235-35-19) , 19-9.5 Rear (265-30-19) with the oem springs. I looking to upgrade with eibach pro kit and bilstein shocks. What size of spacers do you recommend in both set up with no rubing just what that the car looks better
#7291
06 C230 SS 6spd
#7292
C230 kompressor 2005 Spacer
Offset : 35 MM
Bolt Pattern : 5-112 MM
Hub Bore : 66.6
Im want looks wider and nice. So, any suggestions in the two set up is greatly appreciate ... Thanks!
Hub Bore : 66.6
#7295
06 C230 SS 6spd
I'd go 3mm up front and 5mm in the rear. It'll push it out enough to be flush but not rub unless you plan on rolling the fender and grinding the bracket holding the bumper to the quarter panel. With 265 tires its hard to go pretty low on the offset because it'll start rubbing pretty quick. Ask Trutaing about it, he just put 265 on and is running cls wheels and has some rubbing.
#7296
Mercedes C230 Spacer
Thanks for your reply and your suggestions . My Mercedes Benz C 230 Sport is white too . So, if I'd go like you said with oem springs there no rubing, Right ... but if I go with eibach pro kit using the spacers I expect some Rubing? Is going to low to much ?
#7297
2007 C230 Sport
I need everyones opinion i came across a good deal on carlsson wheels 1/6 evo 19x8.5 f et 40 and 19x10 r et 45. My w203 is pure oem all around and is it possible to make this look right? Because the rear wheels concern me on its width. I would like my car to have a oem look... If that make sense (sorry on my iphone)
All opinons concerns are welcome....
#7300
