View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#7601
Like how too long? I have a set from my first car that is about 10mm too long. Is the parking brake only in the rear? I don't believe I hear any contact in the rear. Ill take a quick vid in the am.
#7604
06 C230 SS 6spd
the parking mechanism is pretty close to the hub so you'll have to test them out. you just cant use any bolt if it spins freely. you have to make sure it still threads deep enough to hold the wheel on because if its too short it can cause issues too. From initial turning of the bolt when it catches the threads it should take 6 full rotations to tighten the bolt down.
#7605
#7608
Phister, happen to have a DIY on the wheel studs? I happen to have a 20 ton press in my shop which I assume will be a great help.
#7609
06 C230 SS 6spd
wheel studs is easy... just screw them in like wheel lugs. just apply some BLUE threadlock to the end screwing in and torque it to 20-25ft/lbs and let them sit for a hour. our thread pitch is 12x1.5
#7612
06 C230 SS 6spd
acorn/conical lug nuts are the normal actually for aftermarket wheels. ballseat lugs are the hard ones to find. You can get them at different places, you can buy H&Rs which is the ones above or from other companies. just google wheel stud conversion and a list of companies come up and just see which ones you like and the price.
I paid a little higher price because I bought the race version. Most kit comes with lug nuts
#7613
The longest I can seem to find is 38mm of thread. That won't be enough as far as I can tell. Damn this is quickly becoming not worth the new rims.
Edit:
Called Dorman auto parts. Gave them the thread size and asked for the longest shank they had. 26mm+ 15mm hub penetration. That's 41mm total length. With the 20mm spacers the longest I need is 42mm. Sold in packs of 10. Dorman part number 610-463. Your local autozone/ pep boys/ napa can order it for you. I ordered. Ill report back if it works.
#7614
06 C230 SS 6spd
you dont want more than 5-6 mm hub pentration plus you have too look at studs differently than lug bolts. 38 is just the shank length not including the extra amount that goes into the hub so you'll have a total of 38mm to use for the spacer and lug nut so you'll have 18mm of stud to use if you use 20mm spacers. Just have to becareful how you read the studs because some company will do shank then overall length. If you go too long it'll look weird when you put the lugs on because the stud might stick out of the lug and if that happens you'll need to buy open ended lug nuts.
heres the place i got mine
http://www.motorsporthardware.com/
heres the ones for our cars
http://www.motorsporthardware.com/12...l-stud-kits-2/
#7615
06 C230 SS 6spd
for your case I wouldnt do more than the 57mm conversion plus you can add lug nuts to your order if you want. Company is top notch and good cs since its only a couple of guys
#7616
Just ordered a set of the 57mm black race studs.
Then I hopped on eBay and bought a set of open end acorn locking nuts. And a set of closed end ballseat nuts for the winter/ stock rims.
Thank you for all the help guys! Greatly appreciated. If anyone needs I have the 45mm extended conical bolts for $25 shipped. Brand new.
Stance shot. Not driving like this.
#7617
1 Post
W209, E46 M3 (dead), S54 swapped E46 Touring
These are pictures of the front setup 19x9.5 225/35/19. Will replace them with 235/35 Nankangs to match the rear soon. Stock fenders but will be getting a roll soon. The rear rubbed quite a bit at 9.5+5 but only on dips so i'm back to 9.5+15 until the fender work is done. 90mm stud conversion too.
#7618
06 C230 SS 6spd
yeah my ride is a bit rough on 215/40/18 on 18x9 in front even though my dampening is set pretty soft on my coilovers.
cant wait to see the works on. I remember I had the vs-xx way back when in like 2001 before they became huge here.
#7619
Help
I just bought these rims, and they don't clear the calipers, with spacers, they don't clear the fenders. Any Ideas why?
Rim Material: Alloy
Bolt Pattern: 5x112 Rim Width: 8.5 & 9.5
Hub Bore: 66.6 Rim Diameter: 18
Rim Brand: OE Replica Offset: +45
Rim Structure: One Piece Number of Bolts: 5
http://www.ebay.com/itm/190818417922...84.m1439.l2649
Rim Material: Alloy
#7622
My car was involved in an accident, broke 3 of the rims, so its been in the shop for a while, I'm just waiting for rims and tires. That's why I'm kind of in the dark as far as what he's tried.
#7623
06 C230 SS 6spd
well you really need to go look at it and test them yourself and see what size spacers he's using. with 18x8.5 +45 you can add up to a 20mm spacer without rubbing the fender.
