my 02 c230k coupe panic button and tunnel mode does not work
Old Dec 26, 2002 | 03:36 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
hi all,
i tried on both buttons the panic button and nothing happens! also, i didnt get to try tunnel mode in my old climate unit but got the digital climatronic and tunnel mode does not work (have windows and sunroof open, while driving, hold the recirculate button down to activate right? Thanks for any input as i plan to make appointment with dealer this evening.
Old Dec 26, 2002 | 03:40 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
TAKE IT TO THE DEALER,,,HAVE IT CHECKED,,SOUNDS LIKE YOU MAY HAVE A VERSION CODEING PROBLEM...
AS FAR AS PANIC,,,PROBABLY NEEDS A CONTROL MODULE FOR THE SECURITY SYSTEM/REMOTES
Old Dec 26, 2002 | 03:43 PM
young's Avatar
GLB 250 4matic
did you hold the panic button down for a few seconds?
Old Dec 26, 2002 | 03:51 PM
tberry's Avatar
yep tried holding for about 4 sec. also went up to door IR sensor, away, close range, nada! u'd think they test that stuff before deliverying!!!
Old Dec 26, 2002 | 03:56 PM
DSMIT's Avatar
PROBABLY NEEDS A CONVIENCE CONTROL MODULE SINCE DOSENT EVEN WORK AIMING AT IR SENSOR....
DSMIT's Avatar
PANIC WORKS ON RADIO FREQUENCY,,,WINDOWS AND ROOF WORK ON IR
Old Dec 26, 2002 | 07:38 PM
Lynn's Avatar
Tunnel mode does not work on 2002 coupes. As for the panic button, do you have the car set so that it chirps when you lock it? If it is in the Netherlands setting the panic button will not work.
Old Feb 26, 2003 | 11:15 PM
WebGuyNJ's Avatar
2002 C230K
Lynn: I've been away for a while. Was it confirmed that this is now working in the 2003MY W203? If so, Is there any way to resolve the issue in the 2002's?
Old Feb 26, 2003 | 11:22 PM
Bobdole's Avatar
C32
i have a 2002 and my tunnel mode works fine,and like stated above if yours chirps then your panic is disabled
Old Feb 27, 2003 | 04:33 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
what's the tunnel mode?
Old Feb 27, 2003 | 11:59 AM
MarkL's Avatar
2002 C240 6-spd (ret)
I think tunnel mode works for the coupes, the windows only, not the sunroof. Sunroof needs "one-touch" close for tunnel mode to function (like the sedans). Old topic.
Frank W - tunnel mode is a feature where you press the "recirc" button for 2 seconds. It closes all open windows and sunroof (on sedans). If you press and hold recirc again for 2 seconds (if the ignition hasn't been turned off), the windows and roof (again sedans) return to their original positions. Great feature for "all close" when shutting down...
It's called "tunnel mode" because there are (apparently) many tunnels in Europe. You can use the feature to avoid fumes, etc. when going through them.
Old Feb 27, 2003 | 01:43 PM
mctwin2kman's Avatar
My 2003 closes the roof. But that was not the question, just more of a 'Hey this now works on the new models'.
Old Feb 28, 2003 | 04:26 PM
MarkL's Avatar
Question for you -- does the sunroof switch also have a one touch close position on your 2003 coupe? On the 2002's that I tried there was no one touch close engagement position for the switch.
Old Feb 28, 2003 | 05:04 PM
20FHK02's Avatar
2002 C230 Coupe
I had a 2003 Coupe loaner before. There was a one touch to half open, and 2nd one touch to fully open, but there was no one touch fully close feature.
Old Feb 28, 2003 | 05:06 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my 2003 coupe has 1 touch 1/2 open, 2 touch full open, no one touch close. my tunnel mode works for open/close of windows and roof.
Old Feb 28, 2003 | 06:18 PM
susemu's Avatar
2007 R350
Go and have the dealer fix it. I have a 2002 Coupe and in the beginning my sunroof would not move when pressing the re-circulation button. I went to the dealer and they fixed it. Now everything works as advertised.
Old Feb 28, 2003 | 11:07 PM
Outland's Avatar
2002 C230 Coupe(M111)
Care to tell us what he did? Ive never heard of the panoramic roof closing with tunnel mode on the 02.
Old Mar 1, 2003 | 09:35 AM
susemu's Avatar
2007 R350
Well, it was done with some other work they had to do. I just write what I've got on my worksheet from the dealer:
Sunroof will not open. Also rattles when driving over bumps
and window shade will not operate at all.
Hooked up SDS found codes B1075.B1066
Checked actual values not initialized.
Cleared codes
Sunroof blind operates as designed
Lubed sunroof rails
Operated 15 times ok
They fixed my tunnel mode at the same time they fixed my sunroof. Don't know if the codes have anything to do with it....
