Is there an upgrade to the 7 spd auto software?
Does anyone know of a fix for this, such as a software upgrade, that will improve the shifting speed? TIA.
I'm not sure if the update is done with standard DAS? Or something else.
You should still be under warranty no?
Where in bay area are you? (Just curious)
But, there are multiple software updates for the 7G transmission. In fact, I have my car scheduled for the fluid/filter change and software update next week.
), and drive the car how the transmission wants it driven, you'll both be happier. Or, just use the shifter and make the transmission shift how you want it to shift
Most people really complain about the 7G, but IMO it is a great transmission if you are willing to adapt your driving style to match the behavior of the transmission. It does have a bit of a learning curve. If you have never driven a "drive by wire" accelerator (this is my 1st), that really adds to the learning curve as well.
Only thing I would change about the 7G, would be to change the gear ratios slightly. 1st gear is incredibly low (4.377:1) and 2nd is a little to high. Make second gear a little lower, then change 5th to about the ratio of 4th, 4th a little lower, make 6th gear 1:1 (instead of overdrive), and make 7th the ratio of 6th.
Most people really complain about the 7G, but IMO it is a great transmission if you are willing to adapt your driving style to match the behavior of the transmission. It does have a bit of a learning curve. ....
Thanks for the feedback gents.
One thing I want to make clear with the 7G when driven decisively in AUTO mode - If it is in 5th gear, for instance, and you need to accelerate briskly - give the throttle a good shove and it should change directly to 3rd gear - NOT go first to 4th then 3rd - this is one of the 7G pluses over older designs - If your box does not do this it has a software glitch.
Also - a big no-no with the 7G is what I call yo-yo throttle driving. People who endlessly accelerate & back off (go from positive to trailing throttle endlessly & a lot do). This confuses the 7G, you get change ups & downs - hunting and torque converter lock ups all occuring at the same time and in the worst situations you can provoke a clonk out of the diff and propshaft due to a certain amount of lash being taken up when you catch the box out. This is plainly bad driving. If you want to accelerate past the car ahead of you at three quarter throttle then hold the throttle at 3/4 until you have executed the move and then back off. Under those conditions the 7G will perform faultlessly as designed.
I find many people don't realise just how badly they manipulate the throttle - get out of the bad habit and you will have a nice smooth ride and save fuel. If one is honest about it you can even catch the 5 speed auto wanting if you accelerate hard and snap the throttle off just as the torque converter is locking up with a resultant transmission clonk.
