Fuel System Cleaner
2005 1.8 B/B
Fuel System Cleaner
Hello, i did search but i did not see any thread relate to this topic.
Have you ever use Fuel system cleaner?
Do you think it is useful?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2005 1.8 B/B
Wow. Thanks Frank.
Kragen has the Techron 12oz (Chevron Fuel System Cleaner) on sale.
2 for $10 with coupon at Kragen.
I am gonna get some tomorrow.
I recently bought a C32 with 60k. The idle was shaky, to say the least
I used seafoam (even though techron is supposedly better for your car) but only HALF the recommended amount. I had a half tank, added half the seafoam can (8oz), and filled up with 91 chevron. So for 16 gallons, I used 8oz. Too much might end up doing harm so make sure you use less than 1oz per gallon of gas. My car has a 16 gallon tank. The idle is much smoother. The results were noticable after using up 1/4 tank of seafoam laced gas. DO NOT add seafoam to your oil or vacuum line method.
Seafoam is safe because right on the can it says you can suck it into your intake vacuum line to all cylinders to clean valves/ carbon deposits. It smokes like hell (as seen on youtube) but this is an INTENDED USE by seafoam, so if that is safe adding a little to your gas wont do any harm. Make sure to fill up with good gas like supreme chevron.
I just got back from Kragen. Picked up the 2 for 10 sale.
I noticed they also had Chevron "Pro Gard" FI injector cleaner, seperate from the
fuel system cleaner.
It was only 5.99 normal price... hmmmm...
Both seem to make the same claims.
They also had Shell V-power treatment 2 for 8.
It said to put it in when the tank was empty.
Does it matter? I have about 12 gallons in the tank currently so I just
dumped it in.
I've never run it before. Nice to see if it makes a difference.
dumped it in.
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
on my way to Kragen...
although I'm not having rough idle or start,
but I think anything to keep the injectors clean is worth $10
Carlos
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Saprissa@aol.com
Carlos
Saprissa@aol.com
C3Twon AWD Jumpofffff
i use lucas get the big one its a better deal and fill it up with the smaller bottle
can be easily purchased at autozone or any other auto parts store i use it after every oil change
I believe the idea is to put the cleaner in and then fill up the tank so that the flowing of the gas into the tank mixes the cleaner in with the gas better.
I always used to use this in all of my cars (usually all domestic). I would also be using it in the Benz except for all of the reading I've done on this forum regarding Techron. So I figured I would use the Techron for the Benz and the Lucas for all of my other vehicles.
