Engine Wire Harness, O2 sensor --- Big money
I have a 2003 C230 Compressor. The engine light came on. Took it to Autozone and read the code. It indicated O2 sensor. Took it to the dealer and the dealer wants to replace the O2 sensor as well as the entire engine harness and is asking for $1600. BTW what is this
harness? I am in Tampa FL. Does anyone know what a cheaper, economical way for me to fix this car? Please help.
harness? I am in Tampa FL. Does anyone know what a cheaper, economical way for me to fix this car? Please help.Engine harness is all the wiring. Search the forum & DIYs - there is plenty on changing O2 sensors. They are not expensive & you can do it yourself. If you have trouble finding come back and ask. Change O2 sensor/s. There are 2. Leave the harness & see what happens. If sensor change fixes code then leave well alone.
Why do they want to change the harness? Did they say anything about leaking cam sensors?
I put in new O2 sensors last night (4 on the C320) and it is not hard at all. $150 at Advance and you really only need a 7/8 wrench.
Any competent DIYer can remove the engine harness in 1 hour. Remove it, soak it in degreaser overnight, let it dry out the next day, replace. Spray all sensors and ECU with contact cleaner.
Buy new cam sensors and isolation wires. This fix will cost ~$200 and a few hours on the weekend.
