drove car across country now running rough??
No - the vehicle adjusts itself for altitude change. It has an aneroid arrangement.
I also suspect gasoline problems. A few thoughts:
1. Gasoline purchased in New México tends to be low octane. The entire state is at high elevation, so the octane demands are low. Premium gas is often only 89 to 91 octane, and regular is around 84 to 86 octane. I think this also applies to mountainous areas of Arizona.
2. Temperatures in the mountains are now getting cool, and you may have bought some winter formulated gasoline. Winter gas normally has a lower flash-point than summer gas. Vapor pressure may also be different (could cause "bubbling" in the injection system). Therefore it may run poorly at hotter temperatures.
3. If you travelled the normal route, you came through Flagstaff (elevation 7000+ ft.) and descended into Phoenix (elevation ~1300 ft.) in about 100 miles. Your car feels like it has fallen off a cliff. There are huge differences in temperature, barometric pressure, and demands on your fuel.
Run some Phoenix gasoline (Top-Tier, please) and Techron through your fuel system and see if it readjusts, before you panic.
