Suspension and STeering help
Old Jul 2, 2010 | 06:32 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Originally Posted by Glyn M Ruck
See B220-0643 here under front axle:
http://www.baumtools.com/pdf/Mercede...og_2008-sm.pdf
thanks for the link but $264 for the kit, when new control arms and tie rods are around $290 from rmeuropean...argh..
Its kinda not worth it.
Old Jul 2, 2010 | 07:21 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
awesome list of all the tools
Old Jul 2, 2010 | 07:38 PM
Glyn M Ruck's Avatar
Super Moderator
Sorry Mike - The reason I posted was to show how easy it is to contrive a rig with washers & bolts. There is nothing to it.
Old Jul 2, 2010 | 07:57 PM
MOBC200K's Avatar
c200k
hi glyn looks like no 18 in the picture, that price is for two and its not the complete arm thats buying the arm and the bushing and then having to press the bushing in. I got a price for non genuine control arms and the bushing is already in for about 175 for both how do yous feel about non genuine control arms
Old Jul 3, 2010 | 10:21 AM
Super Moderator
Yeah - that's the castor bush. Damn things. I have no problem with non genuine control arms. Most are made by the OE supplier anyway. You guys pay high prices for things. Same here in SA.
I wish there were non genuine bushes available. They might be better than the Benz ones.
Most people now fit the bush from the W204 - supposed to be better.
What is wrong with your arms? Ball joints?
Old Jul 3, 2010 | 11:52 AM
TemjinX2's Avatar
no apologies needed my friend. Your posts are always constructive and informative. I really wanted the kit, but its pricing kills it on the ROI aspect.
Old Jul 16, 2010 | 11:05 AM
  #32
MOBC200K's Avatar
c200k
just a quick question. I've ordered the arms and should be here mon but is it urgent..... what I mean is seen as the shocks have to come out I was going to hold on a little longer before doing them and lower the car at the same time or will I do more damage
Old Jul 16, 2010 | 12:29 PM
  #33
Super Moderator
Only to Tyres
Old Jul 16, 2010 | 12:39 PM
  #34
fookoo303's Avatar
2003 c240
hey glyn i am getting some play in my front wheel bearing when i wiggle my wheel from the top and bottom. does that mean the bearing is out or can it just be loose? And if its loose how do i tighten it? I opened it up and see the clamp with the hex bolt it. Do i just loosen the hex and turn the clamp? thanks in advance
sorry don't mean to thread jack
Old Jul 16, 2010 | 07:39 PM
  #35
Super Moderator
Yes - Loosen hex nut - tighten clamp - tighten hex nut again. If play in bearing is not removed the bearings need replacement.
Worn bearings usually make a noise. Check that play is on bearing & not ball joints. Do not over tighten. Wheel must spin freely. Don't get crap in the grease.
Good luck
Old Jul 16, 2010 | 11:33 PM
  #36
fookoo303's Avatar
2003 c240
cool thanks again
Old Jul 17, 2010 | 12:26 PM
  #37
fookoo303's Avatar
2003 c240
do the bearings need to be pressed in or can i DIY this?
Old Jul 17, 2010 | 07:21 PM
  #38
Super Moderator
They are pressed - Buy bearings & go to an Indy.
Old Jul 25, 2010 | 06:43 PM
  #39
MOBC200K's Avatar
c200k
Just an update, so i went ahead and fitted the control arms even though i was gonna wait and fit the springs at the same time figured I'd rather have the car driving the way its meant to and not shaking me to death in the bloody thing. The car drives so much better kinda made me think about how long they were actually shot before I noticed them......... so all good there until yesterday the engine light came on put a computer on it quick and came up with bank1 running rich or something like that erased the fault and went home and cleaned the air flow meter and throttle body light stayed off up until about an hour ago so back to being annoyed that the car is playing up ah well could be worse
Old Aug 30, 2010 | 07:20 AM
  #40
MOBC200K's Avatar
c200k
Ok so back on to this. My problem isn't fully resolved car still shakes at 120kph and my head is really getting wrecked at this stage so I'm looking for more help. The shake seems to be in the whole car not just the steering... well thats what it feels like. So ant ideas do the bushings on the prop shafts give trouble
Old Aug 30, 2010 | 08:56 AM
  #41
Super Moderator
I would have the wheels balanced on the car with a finishing balancer.
120 Km/h is a little high for propshaft to show itself but who knows.
Check front & rear flex discs & centre prop bearing for damage. See if there are signs of a balancing weight being thrown off of the propshaft anywhere.
Check the rear subframe bushing & make sure that the pinion nose of the diff is not hanging down it should be horizontal or slightly tipped up.
Check rear gearbox mount - common failure - Benz calls it a rear engine mount BTW for ordering.
Make sure that the centre UJ is not tight.
Old Aug 30, 2010 | 12:07 PM
  #42
MOBC200K's Avatar
c200k
Thanks Glyn I might get the car on the lift before the end of the week and hopefully get it sorted once and for all. I'll post my findings thanks
Old Aug 30, 2010 | 04:56 PM
  #43
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Rear enging/gearbox mount failure is common. My car had the mount "collapse" and didn't do the vibration thing yours is doing, though, so I doubt that's your issue.
Old Aug 30, 2010 | 05:10 PM
  #44
TemjinX2's Avatar
i would go with glyn's suggest and get the tires rebalanced. Also check the tire wear, bad control arms could've thrown your alignment off and made the tires wear unevenly.
You can try cross rotating the tires after the balance and see if that helps.
