HELP Please!!! Alternator Problems!
I have a 2002 C240 with about 125,000 miles on it. My alternator went out a couple days ago so i picked up a new one to replace it. I got the serpentine belt off and started to take off the top bolt, but it was super tight, so i left it and started to loosen the bottom bolt. I got the bottom bolt off easily, but the top didnt get any looser. I finally cracked the top one loose and got it out, but there was so much lock tite or some sort of sealer on the bolt that when it cracked free, it was the housing that the bolt screws into that cracked. The part where the bolt screws into broke into pieces so now there is no way to use the top bolt. Is that a piece that can be replaced or is it part of the entire engine? What should i do to fix this problem?
Any information will be greatly appreciated.
Thanks.
On my car with the 4 cylinder, I was able to see that, that part is separate.
If you are in the US sign up for a free EPC account and you'll be able to see the exploded diagrams.
https://epc.startekinfo.com/epc/coverage.jsp
Here's a diagram I got from there when I did my alt. for the 4 banger.
I had to print screen and use paste to mspaint to save it.
If yours is like mine, you'll just need the replacement 'bracket', or whatever it's called. Don't give up hope until you've checked.
How much am i looking to get it welded?
Also, i got the EPC account but am having a lot of trouble finding diagrams. If you could get the diagram for my car or let me know how to use that program that would be great.
Sign up for free EPC account?
Find the picture and pn?
Ah, OK having trouble?
Just takes a bit of doing..
put in your VIN #...
one of the menu's has a pn search.
Add an "A" to the front, punch in the pn of the
alternator, the drawing should come up, or it may take a bit of surfing the program to find the diagram...not always easy to find what you want but it is there. Take the time to play with it and learn.
If you can't figure it out, go to a dealer.
Lord knows what you'd have to do, to replace the bracket.
You could ask the service guys while you are there...
(ask the parts counter, if he's cool he'll find a mechanic to help answer your questions)
or...ha, send me your vin, paypal me 20 bucks and I'll find the pn and pic for you.
