Re-wiring Seat Modules - Can you use the heated seat wiring for relay?
Old Dec 16, 2008 | 08:28 AM
JLD2k3's Avatar
2002 C320
I looked under the seat and there are plenty of wires under there, presumably one set is the heated seat module. Can I use that wiring instead of the cigarette lighter to power the seat module? Which module is the heated seat? Any help much appreciated.
Old Dec 16, 2008 | 12:13 PM
Utahkompressor's Avatar
W124, W203, W204, W251
wanna know too!
Old Dec 20, 2008 | 10:09 AM
JLD2k3's Avatar
2002 C320
bump
Old Dec 20, 2008 | 03:29 PM
Glyn M Ruck's Avatar
Super Moderator
Ask TemjinX2 - PM if necessary.
Old Dec 20, 2008 | 05:33 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
on my wiring mod, i just used the cig lighter as the trigger originally. Then later i just used a aux 12v source hooked up to a switch to close the circuit. So the seat control module will only work when i turn on the switch.
The module continued to be powered by the original oem source. I tried using a direct 12V source but it wouldn't work.
Only when i used power from the original wires, it work. Just click on my sig to look at the seat module mod.
Old Dec 20, 2008 | 11:01 PM
JLD2k3's Avatar
2002 C320
Thanks,
How do you access the cig lighter wiring? Did you take apart the console?
Old Dec 21, 2008 | 04:34 AM
TemjinX2's Avatar
Originally Posted by JLD2k3
Thanks,
i added some additional instructions and pictures from other threads to give you a better idea to access the wires.
Just check my seat module thread
