Factory GPS in a NON GPS Car????
Whatever I Want!
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Can this be done???
I have seen nice units selling for $500-900 on ebay...
Is the harness the same???
Can this be done???
It is possible, but the units on FleaBay are usually not for MY2005+ W203 cars.
There are many Euro models available, but they do not tune radio stations in the US. Installation will require purchase of the GPS antenna, and version coding by a dealer. There are several models for other Mercedes cars that look similar, but will not fit, and will not send directions to the MFD. One of our forum sponsors can get you the whole package and it will work in your car. You cannot do better anywhere.
MBenzNL.com
MBenzNL.com
2012 C300 4Matic
It's true that eBay has a lot of older models, models for the wrong vehicle, stolen models, etc. But you absolutely can find the correct one legitimately! Just ask the seller for the part number off it. I've seen the correct US MCSII Comand unit sell on ebay anywhere from $400 to $2300.
You only need the unit and antenna which can be mounted in the same area as the unit or preferably behind the gauge cluster. Antennas are also available on eBay, but if you want the real deal MB antenna best bet is the dealer. I don't think its necessary.
After you buy and install those two parts, you may or may not need to have the unit programmed at the dealer. You absolutely must have the gauge cluster programmed if you want directions to show up there as they are meant to along with the comand screen.
eBay is by far the best deal, you will save a ton of money if you wait for the right auction. But as always there is that chance of being screwed with eBay.
I should have just told you to search the forum!
Also FWIW the euro versions will tune *most* FM stations fine in the US. Plenty of AM stations will probably be missing but you'll get some.
But for this reason I wouldn't get the Euro Comand unit.
1 Post
2005 Mercedes C230 Sport Sedan (W203)
Mercedes calls their GPS-capable head units "Comand". Its often misspelled "Command". You might want to try searching this forum a bit, as this has been dicussed to death already and all the information you could possibly need is already here.
Whatever I Want!
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Hey acr2001,
I appreciate the help, I was wondering if someone knew part #'s to the units that work???
as for FrankW,
Don't you have something better to do???
You have logged on to all my posts with something sarcastic to say...
But I guess you were born knowing everything right.
as for FrankW,
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Hey acr2001,
as for FrankW,
But I guess you were born knowing everything right.![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
as for FrankW,
Whatever I Want!
Wow, you must have worked hard on STUPID replys like this one to work up to that 10,000 post you have...![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
You should really get a life!
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
MBworld Guru
white and whiter
Hey acr2001,
as for FrankW,
as for FrankW,
Whatever I Want!
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Oh yeah JKETCH tell me how you have helped me... other than jump into a thread and throw out your two cents???
As for FrankW, and JKETCH other people don't need cheerleaders to state there opinion...
Both of you are highjacking my thread with your ignorant comments...
Please just go find another thread to make yourselves feel wanted!!!
MBworld Guru
white and whiter
MBworld Guru
white and whiter
2005-2007 are plug and play after you make necessary change to the connector pins behind the unit. all you need to activate is the NAV selection for MFD so you can see the NAV route directions on the MFD.
1 Post
Hey acr2001,
as for FrankW,
as for FrankW,
I've seen countless newbies like you come on here, diss some of the most senior users, and they usually end up getting banned within a day or two for it. Its tough to say where you stand right now but you're on thin ice, thats for sure. At this point your best course of action is to apologize and/or ignore this topic, lay low a while, then try again later. If you keep up the flaming its you thats done.
2012 C300 4Matic
![Rcain](https://mbworld.org/forums/images/smilies/rcain.gif)
MBworld Guru
white and whiter
I have a Comand unit on it's way. The donor vehicle had the HK sound system (external amp on the fiber ring). My vehicle uses the internal amp. I was told I would need version coding because the Comand unit won't boot if it doesn't see the amp as it expects. I hope you're right!!![Rcain](https://mbworld.org/forums/images/smilies/rcain.gif)
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Hey acr2001,
as for FrankW,
as for FrankW,
