Noisey Supsension: Help!
2002 C230 Kompressor Coupe
Hey guys just wondering if you guys could help me out. I have a 2002 C230 Kompressor coupe and when I go over speed bumps or rocky roads the front suspension makes squeaky noises, but only sometimes. Any suggestions about what it could be? anything serious?
Super Moderator
Next to go are the castor arm bushes. They crack, leak silicone fluid & usually clonk rather than squeek. If they are damaged usually effects wheel alignment & causes feathering on the front tyres. These are a known weakness
None are life threatening. - Good luck
2013 ML350
Lubricate anti sway bar bushings with silicone grease or replace. Usually the first to make a noise.
2005 1.8 B/B
hmm, i hope this will help.
I went to the dealer last week for the same reason, noise came from the passenger side suspension when i drive over speed bump.
Dealer found the problem and replaced the sway bar link (I hope i did not spell it wrong).
I paid zero because my car is under warranty.
BTW i have 2005 c230 sedan.
Super Moderator
Castor is the angle to which the steering pivot axis is tilted forward or rearward from vertical, as viewed from the side. If the pivot axis is tilted backward (that is, the top pivot is positioned farther rearward than the bottom pivot), then the castor is positive; if it's tilted forward, then the caster is negative.
Positive caster tends to straighten the wheels when the vehicle is travelling forward, and thus is used to enhance straight-line stability.
Mercedes terminology:
Hence those are the Castor Arm Bushings
Oh! & sorry - I spell Castor the English way
Super Moderator
Hey Splinter - I "elucidated" as requested - what happened to your post & sexy picture
Super Moderator
2013 ML350
Ha Ha. So true Glyn. Either way, great info. I was scheduled to have my castor arm/lower control arm bushings changed today (I have the "clonk") but had to re-schedule. We have over a foot of snow here in Orgeon, USA. The wagon is staying in garage for awhile.
