Sunroof - Express Close Issue
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
MB also has a Glass, Metal, Plastic, Paint Cleaner to clean the rubber before the lubrication is applied. A0059891971
Audi A4 Quattro 2013
Resync instructions can be found on the owners manual...
http://pdfservicemanual.com/tag/mercedes-benz-w203
...on page 230
I will give this another try and then its off the the [non-Mercedes] dealer for some warranty work.
...on page 230
FIXED!!! so far ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I did the resync again, I must have done something wrong last time, and its fine now.
For anyone seeking clarification on how to resync; follow the instructions exactly as in the manual link I posted above.
When I did it last night, I didnt have the engine running and the door may have been open. This time I turned on the engine, closed all doors and wholla!
C240
There should be something obstructing the tracks, have it checked. If nothing shows up, try re-sync it, if it doesn't work as well, then bring it to the closest indie..
Same issue occurring once again. Didn't take long.
I put it down to an electrical fault and not the mechanism. The sunroof closes fine when using the feature on the smart-key, but won't operate correctly when using the inside control.
#32
Thanks MBWorld, without your input, the car may have been booked in for a while. But because of advice from here; I went to the dealer, asked if they can lube the sliders before checking the sensor and I was out of there in 5 mins.
