W203: Removing Rear Deck
C Pillar.
Pull door / sill trim / edge guard away from C Pillar area.
You want to pull the C Pillar at the top middle first.
Gently slide the C Pillar Paneling by pulling out of rear shelf guide toward vehicle front.
Basically there are a bunch of clips inside, one with a "crisscross" set of snaps - and then on the bottom a set of LL hooks.
I would locate a picture on line / ebay to see...I will post one as soon as I can.
To anyone that has removed a seat belt mounting point - the torque to reset it is 30NM.
