Now.... what's this???
Old Mar 11, 2009 | 12:37 PM
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by hubertt
Thanks for that quick response. I will definately drive gently.
Dankie.
Dis 'n plesier
Old Mar 26, 2009 | 07:39 AM
maverickdirk's Avatar
05 C230Kompressor SC
Identical instance with my 2005 C230K - same error code. How easy to replace the thermostat? Any help is greatly appreciated - thanks a million.
Old Mar 26, 2009 | 08:09 AM
Super Moderator
Dead easy! Unbolt housing - take out old stat - put in new stat - bolt up. Top up coolant with 50/50% mix of Benz coolant & de-ionized water & get air out of system by squeezing top hose. Cancel P0128 code.
Old Mar 26, 2009 | 01:52 PM
Thanks a million! I'll take a look when I get out of the office this evening and post a reply as such to my progress. I greatly appreciate the sincerity here.
Regards,
Jeff
Old Mar 26, 2009 | 02:59 PM
hubertt's Avatar
BMW 520i, C180
Talking Problem solved!!
I took my Benz today at a new shop that opened and well, they found the problem.... it was just the compressor that needed some service, proper oil, proper gas pressure and THAT'S IT!!! the cooling fan does work
It only cost me $150 for everything they did (diagnostic and repairing)
This is a happy ending story for me.
Old Mar 26, 2009 | 04:47 PM
Super Moderator
That's great news - why was it blowing a fuse???
Old Mar 27, 2009 | 06:10 PM
  #32
hubertt's Avatar
BMW 520i, C180
Red face
Now that's a good question... I guess the compressor was trying to defend itself
Old Nov 4, 2009 | 05:35 AM
  #33
phucmang's Avatar
05 c230k
i think i will have to replace the thermostat, i got the code 128 and "check coolant level" msg..
but i got a question, will we have to drain the coolant first? maybe i should replace coolant while im doing this also... what coolant is recommended? i wanna use something premixed because i dunno which type of water to use.. and rather not mix my self..
Old Nov 4, 2009 | 11:00 AM
  #34
Super Moderator
128 means you need a new thermostat. You will at least have to top up the coolant. You need MB coolant meeting spec 325.0 or 325.1. Buy from a dealer & mix 50/50 with distilled or deionised water. MB premix is not available in the US I'm informed.
Old Nov 4, 2009 | 12:38 PM
  #35
Norwichdelta06's Avatar
2007 c230
I got this message today....
What could it be now ??? This car is so sensitive.
surprise the warning sign doesn't have a $$ next to it lol
