Some help about installing the CD changer
might have to bite the bullit and go to a dealership
greg
The fiber optics connector in the C230K trunk is intended for the factory phone. It is on the same "ring" as the radio so it might be possible to mount a changer in the trunk using this cable (if you do not have a factory phone). There is power in the trunk as well on a 25 pin connector for the phone. I thought about using an older CD changer in the trunk but I have a problem of where to mount it, where to get a power connector that plugs into the changer and what I need to hook up the third wire in the changer connector. I have been told that the third wire is a "reset" from the system to the CD changer but I do not know that for sure. All that being said, I will probably get one for glove compartment.
As far as the older fiber optic changers, they do have a different part number and I am not sure exactly what the differences are.
On other fiber optic MBs, it is much easier to install a CD changer. For a lot of years, to remove an MB radio, you just needed a couple of small tools to unlatch the radio and it would just slide out. You could have it out in seconds. It was also a standard DIN size so other manufacturers radios would fit. Not on the new C class!
On my 99 CLK, it took about 15 mintues total to mount and hook it up in the trunk. I did not even take the radio out of the dash to put it in. Put the mount on the changer, plugged in the fiber optic cable and the power plug and put two screws in to secure it. It does not seem to need any computer setting to make it work although some seem to think it does. My dealer may have put those in for me because I had it serviced a day or so after I installed it.
In my 99 SLK, I just took out the radio and installed a one CD only Becker unit. It took about a minute to install. It is made by Becker but has an MB part number and is sold by MB dealers (not cheap!). It works great. This does not interact with the car's computer at all so there is absolutely no computer changes. My wife likes it much better than the changer. This unit will not fit in the new C class.
