Rubber Shim Perch
"Mercedes-Benz cars ride height may vary due to vehicle options and Mercedes Benz factory ride adjustment shims. This original MB part is a rubber shim perch, which is located on the top of the spring. These shims vary in thickness from 8 TO 23mm."
Can anyone chime in on the stock thickness of these shims on the front of a 2004 c230 coupe? I'm in the process of lowering my car and I'm thinking I would like the front a bit lower. If anyone has part numbers as well, that would be appreciated!
S.
Can't recall the thickness , but MB numbers them 1-4. What pad that was used from the factory depends on how your car was optioned. If they range from 8-23 mm.. i think they go 8. 13, 18, 23. Check out the sponser link at the top of the forum. I think a few of them sell the pads. Dealer has them too.
Post up some pics when you get 'er lowered ! Cheers, Greg
Other than cutting coils, is there any adjustment that can be made in the front that isn't going to throw the alignment out?
S.
Anyhow, not much you can do in the front without installing lowering springs. There's a bunch of options if you want go there. check out this thread on suspension...
https://mbworld.org/forums/c-class-w...de-thread.html
I've got the H&R sport springs. I've measured the distance in the wheel wells and I'm thinking the front will need to be a bit lower.
Thanks for the link! Much appreciated!
s.
Either way good luck on it.
REAR SPRING SHIM W203
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
These are all common with the W210
