changed CRANK SENSOR still stalls :(
I have replaced the CRANK position sensor (pain the hands!!!
) but the car stalled when ti was hot outside and died while pulling into parkingDo you guys think it is the CAM sensor? no codes, battery and alternator are all OK
I am clueless, fuel pump? CAm sensor??
It is a C230 COUPE M111 engine
If it's not throwing codes it could be low fuel line pressure due to pump or blocked fuel filter. I would have expected a fuel trim code running lean bank 1 - but give us some info.
How old is the filter? Put your ear on the passenger rear seat & tell us if you can hear the fuel pump running
Its a 2002 C230 125Kmiles i didnt get any codes thats why its confusing
cleaned the MAF , checked the battery and alternator at Autozone and all are good.
Thats funny, it stalled when I had the AC ON, today it was 85F out and didnt stall but the AC was off :S
But, previous week, I ran the car twice on low fuel :S
Makes sense, no? If I'm wrong please educate me. I'm relatively new to Mercedes and I want to learn all I can about them.
https://mbworld.org/forums/attachmen...k-function.pdf
I had a car that was running intermittently once when the filter got clogged.
You are supposed to replace every 60K miles FYI.
