Whats the offsets and bolt pattern for a W203 C240??
Old Feb 2, 2003 | 03:12 PM
Verb04's Avatar
2019 AMG GT63S, 2020 Ferrari 488 PISTA
Im going to get a pair of custom HRE's and I need the offsets and bolt pattern for my W203 2003 C240??
Old Feb 2, 2003 | 03:23 PM
potatobbq's Avatar
The bolt pattern is 5x112 and I would guess the offset is somewhere around +35... depending on how wide your rims are going to be.
Old Feb 2, 2003 | 06:32 PM
Lynn's Avatar
Stock offset is 37 mm.
Old Feb 2, 2003 | 08:03 PM
Verb04's Avatar
Im ordering a set of 19X8.5 and 19X9.5 for my 2003 C240. And I need the bolt pattern and offset i should order the wheels.
Thanks again
Old Feb 2, 2003 | 10:45 PM
KWiK's Avatar
2002 C230 : 2007 C230
Re: Whats the offsets and bolt pattern for a W203 C240??
HRE will know what you need, the place you are buying from should even take some measuments to be sure you are getting the fit you want.
Old Feb 3, 2003 | 12:59 AM
Verb04's Avatar
Im not getting them from HRE direct. Im getting from a private dealer that orders them according to bolt patterns and offsets. I have a 2003 C240 and I want to run 19X8.5 and 19X9.5
Can someone please give me the suggested bolt patterns and offsets for this set up? Maybe someone who is already running this set up could help.
Thanks alot.
Old Feb 4, 2003 | 01:01 PM
Verb04's Avatar
Does anyone know??? I want to order ASAP.
Thanks again
Old Feb 4, 2003 | 01:21 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Offset should be between +35 to +37
I own a set, but don't remember right now because I'm at sea on a ship. Call HRE [www.hrewheels.com] if you really want a no nonsense answer to your question.
Old Feb 4, 2003 | 04:16 PM
Lynn's Avatar
The bolt pattern is 5 x 112mm. So far as I know this is standard for all MB's. The bolt diameter is 12mm.
