Miles per tank.
Now, I have to start wondering, if I were on a long road trip (say 5000 miles) and I were to continuously go 55-60 and achieve 700 miles per tank vs going 65-75 and achieving only 450 miles per tank, and assuming that it takes about 10 minutes to fill up (get off the highway, stop the car, fill up the car, and get back onto the highway); it seems like it's barely worth it to speed, since you barely save much time at all. Naturally, driving 55-60 on a highway may not be a safe speed, and 65-75 might be more close to the flow of traffic. Therefore, one should not attempt to "hypermile" even in the name of science.
No, I sold it like a couple years ago. Well, it's basically just reducing the amount of effort when you push the gas pedal. You'll like it after you install it, but you need to adjust how you push the pedal. I was like reving after I installed it, cuz I just pressed it like it was without the booster. Definitely fun, but watch out for the popo...
05 C230K SS 49000 miles (original sparks and stuff)
http://www.budster.freeservers.com/c...16-09_2106.jpg
I only drove about 20 miles, and there were no hills. So this isn't something I could sustain for long drives but it's the highest I've seen this read. The highest I've seen it read over a long distance of like 90 miles was a consistent 34mpg.
I only drove about 20 miles, and there were no hills. So this isn't something I could sustain for long drives but it's the highest I've seen this read. The highest I've seen it read over a long distance of like 90 miles was a consistent 34mpg.This is because a 05 C230 Kompressor with the 4-cylinder supercharged engine seems to be designed to have gear shifts done at closer 3000 RPMs during normal non-aggressive stop-light acceleration, while the 06/07 C230s with 6 cylinder engines seem to have gear shifts done at lower rpms during normal stop-light (at least with my driving style).
Having driven C55s on a few very memorable occasions, I can say, the abundance of power in reserve is a great comfort; driving C230 Kompressors, one has to be careful to be in the right gear during tricky merges onto freeways to ensure that adequate power is always available should one call for it. The C55 and even the C320/C350 cure this problem as power is usually sufficient in any gear.
